Author Topic: Aerokits Sea Commander  (Read 4461 times)
dotslad
« on: May 14, 2013, 01:08:08 pm »
Hi all
Well the sea commander kit arrived today looks to be an excellent kit can't wait to get started.
I will start a log and post pictures of my progress just off to read the instructions and make a tentative start on the hull.
I expect you will be hearing quite a lot from me in the very near future (asking for help and guidance)
regards to all Ian  :-) :-) :-) [size=78%] [/size]
Guy Bagley
Re: Aerokits Sea Commander
« Reply #1 on: May 14, 2013, 04:16:32 pm »
there is a nice model  ( which i am pretty sure is a sea commander) which turns up a black park most sundays, - the bloke is from uxbridge/ denham i think, - he runs it on lipos, - goes really well.....
Terry
« Reply #2 on: May 14, 2013, 04:42:14 pm »
Hi Ian,
Have nearly finished my Sea Commander, will post some pictures when completed. Any questions, just ask.
Cheers, Terry
dotslad
« Reply #3 on: May 15, 2013, 12:25:35 pm »
picture of work in progress waiting for glue to dry
Finding this to be a really good kit
Ian :-)
dotslad
« Reply #4 on: May 18, 2013, 05:38:48 pm »
Couple of pictures of latest progress finding this a real pleasure to build
dotslad
« Reply #5 on: May 25, 2013, 01:38:48 pm »
Latest pics of sea commander build
I am thinking of painting the hull with ordinary spirit based paint (Dulux) or similar primer undercoat and gloss also I have some P38 which I want to use as a filler.
Any advice or comments would be most welcome.
Ian :-)
ardarossan
Re: Aerokits Sea Commander - paint an FILLER question
« Reply #6 on: May 25, 2013, 03:17:42 pm »
The paint should be fine, just prep' well and take your time. How are you thinking of applying it?
As for the filler, if you check out Stavros' paint thread, you should find the name of his recommended filler, which is apparently easier to sand than P-38 - Thus reducing the risk of accidentally sanding away the wood, which is a possibility when using a harder filler (i.e. P-38).
Bear in mind, the responses may be a bit slower today as several of the  lucky b****** are playing at Wicksteed.
Andy
p.s. I've modified the title of my reply in this thread so that it attracts the attention of the Wicksteed chaps and chappesses
How much wood would a Woodchuck chuck, if a Woodchuck would chuck wood?
dotslad
« Reply #7 on: May 26, 2013, 02:29:37 pm »
Andy thanks for your reply I will be using a brush as i spent many of my early years painting and decorating for a living
regards Ian :-)
ardarossan
« Reply #8 on: May 26, 2013, 02:42:12 pm »
regards Ian :-)
In that case, use Polyfilla, a coat of Size and then Cross-line and Wallpaper it!  {-)
Andy
dotslad
« Reply #9 on: June 03, 2013, 09:59:30 am »
Latest pics of sea commander progress
coming on slowly
« Reply #10 on: June 03, 2013, 10:11:45 am »
 Looking good!    :-))
Page created in 0.044 seconds with 19 queries.
