Author Topic: Brushless motor & esc for Robbe lightening  (Read 3183 times)
woodley miniman
« on: May 15, 2013, 07:26:51 am »
HI all, can anyone recommend a brushless motor & esc for a Robbe Lightening? I've recently purchased the boat secondhand and it's not as fast has it could be so I thought I'd go brushless instead of replacing the brushed one. The boat is single hull and 790mm long.
Thank you  :-)
Re: Brushless motor & esc for Robbe lightening
« Reply #1 on: May 15, 2013, 10:27:38 am »
Robbe Lightning! - Nice hull.   :-))
« Reply #3 on: May 15, 2013, 12:04:26 pm »
Motor is a nono on 22.2v
Only 14.8V.
« Reply #4 on: May 15, 2013, 01:46:46 pm »
Only 14.8V.
??? not sure what that means Ned, could you use 'idiots terms' please?   :embarrassed:
Ebay speed controller - "Water cool brushless 100A ESC BEC output 5A Speed controller for RC Boat"
 Just be aware that they are 'Hong Kong Amps'... which are a bit like "dog years!!!"
 ( they may be a little.... "generous" with their specifications!  ok2
« Reply #5 on: May 15, 2013, 01:51:51 pm »
The motor is rated at 14.8v max.
Not advisable to run it on 22.2volts.
No no= negative negative {-) {-)
woodley miniman
nick_75au
    • Logan City Marine Modellers
« Reply #7 on: May 20, 2013, 11:44:04 am »
What size prop is on the boat, what voltage do you want to run. they are the questions that really need answering. Basically for a FE boat you wat to keep no load RPM to below 35000 RPM  so 35000/ battery volts will give you an approximate Kv value to look for. the first motor may well be OK on 22 volts with a small prop but I think it my be too small for the lightning.
On an inferred guess though I think a 36 series motor would be better than a 28 series, they have greater torque to spin what I think you might have for a prop.
Example
http://www.ebay.co.uk/itm/Brushless-watercooled-motor-1800kv-3688-2S-to-6S-6volt-22volt-/121111401282?pt=UK_ToysGames_RadioControlled_JN&hash=item1c32cd5342
but in a Kv to suit your preferred battery voltage as per the above formula, you can use a lower Kv than the formula calculates if you are happy with less speed with greater runtime but don't go with a higher Kv.
Nick
Page created in 0.028 seconds with 18 queries.
