Author Topic: Viper Marine 15amp ESC setup etc.  (Read 3972 times)
Rottweiler
« on: May 21, 2013, 12:49:53 pm »
My pal on here,Regiment has asked for help with a connection diagram,and if needed a programming sequence for a Viper Marine 15amp esc,kindly donated to him by a fellow member.Could anyone help him out please?
Thanks,
Mick F
Topic renamed.  Admin
Re: More help wanted for member Regiment please!
« Reply #1 on: May 21, 2013, 01:30:32 pm »
Mtroniks.net have all the info you need
Instructions and connections.
On my phone so can't paste a link.
I could post Regiment a copy of the leaflet supplied
if needed.
Is it a plug and play or one with a setup button?
If you need a copy just pm me
Rottweiler
« Reply #2 on: May 21, 2013, 01:32:23 pm »
Hi Ned,
thanks for that,I will PM you.It is plug and play.
Mick F
« Reply #3 on: May 21, 2013, 02:20:13 pm »
Connect everything up Switch on as soon as you have you NEED to depress the silver button on the esc this should get the lights flashing on it,when it goes gree push your LEFT stich right to the top for a few secs and then down to the bottom and then return to the centre,wait a couple of secs and it should then work for you
« Reply #4 on: May 21, 2013, 02:27:59 pm »
It,s Plug and Play
Does not have a setup button.
« Reply #5 on: May 21, 2013, 02:57:47 pm »
wicker
« Reply #6 on: May 21, 2013, 06:18:34 pm »
Regiment will be getting a new 25amp sent to him with the instructions
Rottweiler
« Reply #7 on: May 21, 2013, 06:23:17 pm »
 Thanks Wicker,he will really appreciate that.
Mick F
wicker
« Reply #8 on: May 21, 2013, 06:25:13 pm »
I like helping someone if I can--Charlie
« Reply #9 on: May 21, 2013, 06:25:59 pm »
You are  Gentleman Sir  :-)) :-))
« Reply #10 on: May 21, 2013, 06:42:13 pm »
Indeed he is.......charlie helped me and my bunch of cohorts greatly on our Loch Ness sail two years ago..raising money AND  support on the day at Loch Ness ........he is a real gent.
neil.
wicker
Re: Viper Marine 15amp ESC setup etc.
« Reply #11 on: May 21, 2013, 06:48:10 pm »
thank lads i might need help someday
regiment
« Reply #12 on: May 22, 2013, 05:13:15 pm »
  i would like to say a big thank you to wicker for the esc  .he gave me regiment
Page created in 0.527 seconds with 17 queries.
