Author Topic: who makes a very very small 40 Mhz receiver?  (Read 2949 times)
U-33
  • K-157 Vepr. Akula-11
Re: who makes a very very small 40 Mhz receiver?
« Reply #1 on: June 06, 2013, 10:35:42 am »
I don't think you'll get much smaller than the first one on your list, E2V...I shopped about for ages when I wanted a tiny rx for my little Kilo, and found this one was about the smallest. And they work well underwater too...bonus.
« Reply #2 on: June 06, 2013, 10:44:44 am »
After a few hours searching I had come to the same conclusion ah well.... it should fit in the little project I have lined up
and yes it will be going underwater  :-))  (deliberately that is)
craggle
  • Boaty McBoatface
« Reply #3 on: June 06, 2013, 04:03:49 pm »
How many channels do you need?
If you can find a 2 channel it may be smaller as it has half the job to do?
Craig.
Model Slipway Envoy tug built.
Huge Lifeboat under construction.
Subculture
    • Dive-in to Model submarines
« Reply #4 on: June 06, 2013, 04:14:02 pm »
« Reply #5 on: June 06, 2013, 04:51:34 pm »
very nice... and quite pricy too.
I think I can get away with the corona synth for now.
But those micro RC planes look very very interesting
Subculture
« Reply #6 on: June 06, 2013, 05:01:58 pm »
Well you're paying for European rather than Chinese labour rates, plus much smaller market (no pun intended) for this type of kit. The Corona receivers are superb value for money, and can be made smaller if you are able to carefully unsolder the plugs from the board, and hard wire the servos in.
« Reply #7 on: June 06, 2013, 05:04:30 pm »
well I can hard wire decoders into N gauge model trains
Davew
« Reply #8 on: June 06, 2013, 07:12:38 pm »
Have alook at DT Receivvers  these are small and are 2.4 ghz.
DaveW
I am not sure about this
Subculture
« Reply #9 on: June 06, 2013, 07:14:15 pm »
Won't work underwater I'm afraid.
hmsantrim
« Reply #10 on: June 06, 2013, 08:20:55 pm »
Hi.
 The HITEC ZEBRA   40Mhz 6ch rx    36 x 25mm  17mm high  This is  1/4 inch smaller in length and width than a futaba micro RX and has extra long range
  Frank
« Reply #11 on: June 06, 2013, 09:52:48 pm »
Cheers for the replies guys... I need at least 3 channels and can't use 2.4ghz as its a diving model.
Going to wait and go for the microinvent one when i have a bit more cash as it has a built in ESC
