Author Topic: Metal or plastic gears?  (Read 3595 times)
seagate
« on: June 17, 2013, 02:26:42 pm »
Can anyone tell me whether there's any advanhtage in fitting metal as opposed to plastic geared servos in my case? My boat is a small tug which has a single rudder measuring 45mm x 30mm.
Thanks in advance,
Re: Metal or plastic gears?
« Reply #1 on: June 17, 2013, 02:55:28 pm »
Metal gears are much harder wearing and are 'usually' fitted to the 'better' servos.
« Reply #2 on: June 17, 2013, 03:07:46 pm »
Yes metal are normally stronger and do last longer, the downside of metal however is that they can be noisier in operation and if there is a problem (ie jammed rudder) you are more likely to burn out the servo motor/electronics than just strip a gear or 2.
In my opinion plastic gears are fine for most boats.  If you are racing or have a big heavy boat then metal gears could be an option.
I do use metal gear servos in the Kids RC cars, but then the steering servo on an offroad RC car takes a lot more punishment that a rudder servo in a average model boat (especially with my stepdaughters at the controls!)
dusty
« Reply #3 on: June 18, 2013, 02:53:59 pm »
I'd  go for the cost, cheaper to replace a plastic servo than a metal geared one.
if there is a problem better the plastic breaks than the rudder is damaged.
Subculture
    • Dive-in to Model submarines
« Reply #4 on: June 18, 2013, 06:19:39 pm »
Plastic gears should be longer lasting than metal. Has anyone here actually worn a set of gears out on a servo. I've busted a couple, but never actually worn them out.
They won't take overloading like metal gears, but that is very unlikely to be an issue in boats. Cars and helicopters are the hardest on servos.
« Reply #5 on: June 18, 2013, 08:26:17 pm »
Usually when plastic gears wear out,  they snap teeth...
« Reply #6 on: June 18, 2013, 08:33:12 pm »
Now that you mention it no..... I usually strip the teeth following some kind of impact  :embarrassed:
Also a good quality plastic geared servo will outperform a cheap metal gear one
« Reply #7 on: June 18, 2013, 08:41:40 pm »
???!!!!! Never! I challenge you to a dual sir! Servos at Dawn!
« Reply #8 on: June 18, 2013, 08:48:38 pm »
Dawn?
Why not a bit later when the server is down O0
... Ah The Devil made me do it Martin :embarrassed:
« Reply #9 on: June 18, 2013, 08:52:08 pm »
No theres a thought Servo Tug o war! maybe a challenge for the next mayhem weekend
sparkey
« Reply #10 on: June 19, 2013, 09:39:23 am »
 :-)) I have no preference myself, some of the composite plastic's that  are out now are as strong as steel and very hard wearing so you pay your money and take your pick,the better quality servo's will alway's be strong whatever the gears are made of,Ray. :-)) :-))
CF-FZG
« Reply #11 on: June 19, 2013, 10:25:49 am »
Hear, Hear!! :-))
Mark.
Tonka Toys - Big boys toys :)
Page created in 0.041 seconds with 17 queries.
