Author Topic: Futaba 6J in model tug  (Read 2470 times)
Alanmclellan
« on: July 07, 2013, 10:22:30 pm »
Has anybody had any experience of using a Futaba 6J radio installation in a twin screw tug with electronize FR30HX units. The instruction manual only discusses aircraft and rotary craft.
Re: Futaba 6J in model tug
« Reply #1 on: July 07, 2013, 10:35:07 pm »
As long as it is either 27/40 mhz or 2.4 ghz then it will be fine.....All radios are biased towards the fly boys and NO info at all for us mariners
tony23
  • IOM, Marblehead Yachts
« Reply #2 on: July 08, 2013, 07:52:54 am »
I use the 6j and 8j models what do you need to know?
ukmike
« Reply #3 on: July 08, 2013, 08:03:53 am »
Hi Alan.
P.M.sent
Alanmclellan
« Reply #4 on: July 09, 2013, 08:21:00 am »
Thanks for your information on the subject. I am going to purchase a Futaba kit that will modify the left stick to allow it to sping to self centre and then follow your advice. I have seen elsewhere that my radio gear does not work with all speed controllers, so I am looking into that issue as well.
dusty
« Reply #5 on: July 13, 2013, 10:09:35 pm »
hi
I don't know what you have been told  but look at the f14 navy it solves all your problems.
dusty
Alanmclellan
« Reply #6 on: July 13, 2013, 10:25:43 pm »
Thanks for the information. I have solved my problem by buying a new radio set that is compatible with the ESCs' that are already in the boat. It is a Hitec AFHSS -Optic6 Sport which a club member kindly set up for me. My Imara tug now runs a treat and can turn in its own length.
dusty
« Reply #7 on: July 14, 2013, 05:52:44 am »
Hi
Glad to here your sorted enjoy you sailing.
If it works for you then that's all that matters
dusty
