Author Topic: Newbie question: Valve packing  (Read 2106 times)
muleears
« on: July 20, 2013, 07:26:16 pm »
What is it and what is it used for?  And should I be utilizing it somewhere?
Cal
Washington, NC USA
Proud owner of:
75% complete Krick Victoria
75% complete Billing African Queen
Krick Alexandra
Lots of building, very little steaming!
kiwimodeller
Re: Newbie question: Valve packing
« Reply #1 on: July 21, 2013, 11:03:18 am »
I have seen graphited string, teflon pipe thread sealant (rolled in to a string) and Viton o rings used for glands. Only needed for things like slide valve link rods or a piston rod where you have a rod passing through a housing and moving with a sliding action not a rotating motion. Hope this helps, Ian.
muleears
« Reply #2 on: July 21, 2013, 12:17:03 pm »
Thanks Ian, that's very helpful, now I think I understand what it is used for.   The only motors I own are a PM Research 8M (V twin, which I built and uses teflon O rings), a Krick twin (which is old and may use it) and a new Stuart Puffin (which I think uses O rings also).  I have not had the Krick apart. I suppose that is something that needs investigation as it does have some years on it.
Thanks Again,
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
« Reply #3 on: July 21, 2013, 12:37:56 pm »
Guys.......I think you will also find graphited twine is used as the steam joint on many valve spindle glands in both model [1/8"] tube size needle & globe valves as manufactured in the UK.......
When we consider the spindle shaft as approx. 2 mm diameter...what a perfect solution  :-)) ....as the geometry for a captive o-ring  would be  <*<  ...........Derek
Page created in 0.355 seconds with 17 queries.
