Author Topic: brede lifeboat  (Read 7431 times)
Workboat
brede lifeboat
« on: August 16, 2013, 03:25:24 pm »
Hi everyone hoping to purchase one of the following brede lifeboat hulls but cant make my mind up which one to go for  so was looking for some advice from anyone who has had any experience with models by design hull deck cabin or kingston mouldings hull cabin plan products regarding accuracy and quality was also looking for address to obtain some plans for this vessel,there arent a lot of builds around on this vessel so finding information limiting ,any information would be much appreciated thanks for now Dave
gribeauval
Re: brede lifeboat
« Reply #1 on: August 16, 2013, 03:40:04 pm »
Contact RNLI HQ at Poole,  The engineering secretary will sort you out with plans for the Brede.
mailto:[email protected]
True Lifeboat Nutter!!
Workboat
Re: brede lifeboat
« Reply #2 on: August 17, 2013, 11:25:58 am »
hi mike thanks for your reply I will send an email ,no realy suprised no one else has replyed as this lifeboat is not looking very popular, judging by the amount of information available  online ,would be intrested why people  dont find this lifeboat atractive as a model build .also tryed the spell check ,but it just seems to wipe my post clean any body any ideas why thanks Dave
Workboat
Re: brede lifeboat
« Reply #3 on: August 17, 2013, 11:51:33 am »
Hi Mike just tried to send email to rnli regarding plans but it has bounced it back if you don't mind could you re check address for me,also sorted problem with spell check so no need for anyone to reply  on that one thanks Dave
casta
Re: brede lifeboat
« Reply #4 on: August 17, 2013, 12:41:23 pm »
This may be of interest...
http://philsworkbench.blogspot.co.uk/2009/01/vic-smeed-to-rescue.html
found by googling: brede lifeboat vic smeed plans
davidjt
  • north wales coast
Re: brede lifeboat
« Reply #5 on: August 17, 2013, 01:01:42 pm »
hi this is a brede i built some time ago sails really well. at 16 inches i intend to build one at thrty inches this back end hopefully
david
Re: brede lifeboat
« Reply #6 on: August 17, 2013, 01:17:02 pm »
Hi Dave.......the possibility is that:
a) the Mersey is a far more attractive boat to most people's beliefs, and as such, many modellers prefer to build that class of boat
b) the Brede, was a sort of Mongrel hybrid being a converted Lochin Marine International  hull and fishing boat, and although gave excellent service within the RNLI, was to many a substitute for the Medina class ( jet drive and very unsuccessful rib) whilst the Mersey and the Arun class boats were developed.
However, it's all personal choice and a lot of people condemn the Solent class boat as ugly, plain and top heavy......lest we forget the Tamar when it first appeared................... so don't be put off because not many have replied to your requests for info..............you might get the same response to any lifeboat, not in the main stream of things.
any model, and all lifeboat models are beautiful things, in my mind, so crack on, and enjoy the build and the sailing of her.............you'll always be welcomed at a lifeboat rally with a Brede.
As for my next lifeboat............I fancy the Thames class...............now that is a mongrel...........but I like them, so long as I can eventually fnd the plans I have for her somewhere.
davidjt
  • north wales coast
Re: brede lifeboat
« Reply #7 on: August 17, 2013, 01:51:28 pm »
hi dave,
should read as [email protected] it is missing the (.uk) on the above message hope that helps.
davidjt
barriew
Re: brede lifeboat
« Reply #8 on: August 17, 2013, 03:06:14 pm »
Davidjt
Did you build your Brede from RNLI plans?
Barrie
davidjt
  • north wales coast
Re: brede lifeboat
« Reply #9 on: August 17, 2013, 04:26:22 pm »
hi barrie,
no I did my own drawing from measurements that I had from Nicolas leach book and some pictuers I had collected, that is why I made this 16 inch one all from cardboard then coated with resin and tissue paper then painted with humbrul paints. its a brilliant boat for sailing. as I said hopeing to enlarge to about 30 inches during the winter plank on frame.
davidjt
Workboat
Re: brede lifeboat
« Reply #10 on: August 22, 2013, 07:55:19 pm »
Hi and thanks to everyone who replyed with information and advice reguarding the brede I will be going ahead with the build in due course once I recive my plans from the rnli ,the brede build with glass hull and cabin will alow me to obtain a detailed looking model in a relativly short time I will hopefully try to place some posts on here of my build ,if anybody has any photos that would help in my build of the brede, that dont appear on  the internet ,if they would like to send me  of the model or real boat it would be much appreciated thanks for now Dave,
Guy Bagley
Re: brede lifeboat
« Reply #11 on: August 22, 2013, 10:54:50 pm »
i have had a brede hull and cabin from kingstons, its was top quality, i can only speak from my experience, also dont forget macs mouldings do a few fittings for a brede like the door and windows
alan colson
  • I Just Dabble In Model Boats
Re: brede lifeboat
« Reply #12 on: August 24, 2013, 12:18:59 pm »
davidjt, may I make a suggestion, build your model 33" oal this will be 12th scale as the boats where 33 foot. Alan
davidjt
  • north wales coast
Re: brede lifeboat
« Reply #13 on: August 24, 2013, 12:33:08 pm »
hi alan ,
just been reading through and should have put 32 inches, as the one I built at 16 inches doubled would work out at 32inches so if i add another inch will be perfect.
thanks for pointing out to me.
david
alan colson
Re: brede lifeboat
« Reply #14 on: August 24, 2013, 12:49:59 pm »
No problems David, I have a model on the bench at the moment that I am building, it is also a Brede, but I am building 33-01, the prototype boat, I have tracked down the real boat that is now in the hands of Yarmouth Marine Services on the Isle of Wight, the owner has a model of the boat that was built by the apprentices at Lochin Marine and he sent me about a dozen pictures of the model plus a photo of the boat in it's present state painted up in his company's colours. Alan
davidjt
  • north wales coast
Re: brede lifeboat
« Reply #15 on: August 24, 2013, 03:09:59 pm »
hi alan
its nice when you can track down existing boats, makes it more interesting. are you doing a build log on here.
david
alan colson
Re: brede lifeboat
« Reply #16 on: August 24, 2013, 03:55:11 pm »
Sorry David, no log build, it's already taken me an age, but it will be finished one day. I have not seen the prototype on the lakes I have sailed on or the shows I have been to. hopefully when finished it will be of interest to many people. Alan
