that's interesting Neil.....I looked a comparison between polyurethane & aliphatic resin as below ...Derek
________________________________________________________________________________________________
Polyurethane Adhesives and Sealants
Products and Brands: Gorilla Glue, .............................................; Sikaflex ......................................................
- Where to use: Bonds a variety of materials - metal, stone, wood, ceramics, foam, glass and more.
- Do not use for: Paper products or rubber materials.
- Cure time: 1-2 hours and longer depending upon formulation, one component and two component versions, moisture curing adhesives.
- Cautions: Avoid skin and eye contact. The use of protective gloves is highly recommended.
Polyurethanes are offered in both one-part and two-part systems. They are simple, strong and easy to use. Polyurethane adhesives are ideal for the laminating of porous materials like wood.
Polyurethanes are water proof
, but moistening the surface before applying accelerates the curing process. Polyurethane adhesives are available in flexible and non-flexible formulations. Polyurethane adhesive sealant products form an extremely strong bond while retaining flexibility and strength above or below the waterline. Watertight bonding / sealing of fiberglass, gelcoat and wood. Alcohol should not be used when preparing surfaces for bonding as it will stop the curing process, causing the adhesive to fail. Polyurethane sealant products are not recommended for use as a teak deck seam sealer. Extended exposure to chemicals (teak cleaners, oxalic acid, gasoline, strong solvents and other harsh chemicals) may cause permanent softening of the sealant.
Aliphatic Resin Wood Glue (aka Yellow Wood Glue)
Products and Brands: Titebond Original Wood Glue
- Where to use: A wood glue designed to work on porous materials only.
- Do not use for: Non-porous materials and surfaces. Not for structural or load bearing applications. This glue is not intended for exterior use or where moisture is likely
. - Cure time: Fast setting.
- Cautions: Avoid prolonged or repeated skin contact. Use only in well ventilated areas.
Titebond Original Wood Glue is ideal for wood, hardboard, particleboard, leather, cloth and most other porous materials. Titebond Original is easy to use, non-toxic and cleans up with water. Also known as yellow glue or carpenter's glue.
