Pages: 1 [2] 3   Go Down
Author Topic: Thunderbolt twin electric build  (Read 18510 times)
fastvee
  • budget builder
Re: Thunderbolt twin electric build
« Reply #25 on: July 17, 2016, 01:03:38 pm »
I did look at your build earlier today.
Looking great!
I will use a window seal foam tape on the cat and m4 bolts to keep the lid on and hoping it is enough to keep the water out. I dont want to tape it shut after doing all this work to get good paint on! -and then risk of pulling the paint off with the tape...
This will have Gulf racing colors when done(allready got the paint, darn expensive to get correct color mixed in spray cans...)
-Pate
martno1fan
« Reply #26 on: July 17, 2016, 07:32:50 pm »
Yea thats what i used for the seal ,hoping its enough just in case she does flip .
fastvee
  • budget builder
« Reply #27 on: July 29, 2016, 05:23:26 pm »
Small update, 1s color is on
fastvee
  • budget builder
« Reply #28 on: August 06, 2016, 08:45:13 am »
the not so great update... -the masking tape melted somehow the paint under it... -did everything like instructed by the paint store owner.(other then letting the paint cure 3 days instead of 1 hour he told me... crap. I did manage to fix it 97% pics of that later.
martno1fan
« Reply #29 on: August 06, 2016, 01:17:23 pm »
That sucks,hope you manage to sort it Pate .
fastvee
  • budget builder
« Reply #30 on: August 07, 2016, 09:45:25 am »
After wetsanding and clear lacquer,wetsanding and polishing
Looks better but I did not want to clear this because the black dust specs that allways find their way in :( -not too bad but from very close you can see some dust inside the clear.  -but this is ok, this is a speedboat that will get few hits Iīm sure...
martno1fan
« Reply #31 on: August 07, 2016, 01:39:18 pm »
Looks shiny  :D .
fastvee
  • budget builder
« Reply #32 on: August 10, 2016, 09:59:42 am »
Color is on, only the hatch has been varnished.
More to come soon...
martno1fan
« Reply #33 on: August 10, 2016, 01:11:06 pm »
Looking good Pate  :-))
fastvee
  • budget builder
« Reply #34 on: August 11, 2016, 02:20:57 pm »
Thanks Mart. Just cant wait to slap the decals on and hit 2k clear on....  %%   the paint shold be done saturday or sunday. Then the assembly begins and hopefully will get this wet in about a week.
-Pate
martno1fan
« Reply #35 on: August 11, 2016, 10:39:23 pm »
Look forward to seeing her when shes done mate and cant wait to see how she runs  :-)) .
fastvee
  • budget builder
« Reply #36 on: August 11, 2016, 10:59:57 pm »
wetsanded,polishing left to do,then it is hardware install time.
martno1fan
« Reply #37 on: August 12, 2016, 08:21:24 am »
She looks great Pate,should buff up nice  :-)) .
fastvee
  • budget builder
« Reply #38 on: August 17, 2016, 08:23:56 pm »
Big boat but there is also alot of stuff inside.
The prop shafts are really long so I needed to make spacers between the props and nuts. -this should not be a problem?
Maiden this weekend if the weather allows.
Still not polished the paint, will do that later.
martno1fan
« Reply #39 on: August 18, 2016, 05:27:39 pm »
What size props are you using mate ,wouldnt worry too much about the length of that thread ,its because those shafts are made for gas props which are much bigger but as you say use some spacers,you could use some silicone tubing maybe ?.
fastvee
  • budget builder
« Reply #40 on: August 19, 2016, 06:46:05 pm »
The props in pic are 45mm .tested 45 and 51mm props, temps after 1 minute , 25-28c 😃
I guess I can try the 57mm next...
the hatch seal was worst try ever... 20sec and boat was half full with sea.
glad the electrics were fine after ri sing and drying...
https://www.youtube.com/watch?v=8n0-X5J7ppI
 test with 45mm and tAped hatch.
https://www.youtube.com/watch?v=-hI-hWAnuBc
test with 51 and taped hatch. some water was in but nothing bad.
martno1fan
« Reply #41 on: August 20, 2016, 11:45:46 am »
Wohoo shes alive  :-)) ,congrats on the maiden .Sorry to hear your hatch seal idea didnt work any idea why ?.
She looks to run well even with those smallish props,good turn of speed and trim seemed spot on congrats .
fastvee
  • budget builder
« Reply #42 on: August 21, 2016, 10:56:19 am »
i dont know what went wrong with the seal.
but the boat still collects water,looks like ghe stuffing tube leaks .thinking what to do. tried shrink tubing the end but no help.
looks like the flex shaft just sucks water...
martno1fan
« Reply #43 on: August 21, 2016, 12:23:57 pm »
fastvee
  • budget builder
« Reply #44 on: August 22, 2016, 05:57:07 pm »
thanks Mart,i ordered 1/4 versions of the seal units.
will try some home grown sealing for now,looks like the boating season is soon ending and dont know how long it takes to get the parts.hoping less then a week...
fastvee
  • budget builder
« Reply #45 on: September 08, 2016, 07:22:45 pm »
Video shows yesterdays run first and todays next.
Did try today again with better cog.
https://youtu.be/tdd-e8w3wHg
After few minutes, the motors were really hot(77c after 3 minutes of cooling,forgot the temp gun to shore). Escīs cool 37c and lipos 35c
There was some smoke when I opened the hatch,but it looked like burned oil not electricity.
The new shaft seals looked a bit burned so bearing update is soon to follow (smoke visible on video.)
thinking this needs watercooled motors and bigger props since the escs were cool?  motors are salt water dunked few times so they may be going poof soon.
Gps 93kph not bad imo.
martno1fan
« Reply #46 on: September 09, 2016, 08:18:08 am »
Looks to be going well Pate,maybe water cooled mounts will help the motors ,also maybe rig up the oilers on those shaft seals might help too.93 kph or 57 mph is fast considering you didnt really keep the hammer down for long due to conditions,cog more forward will help when its rough,even a little weight added forward when its choppy thats removable for when its flatter would work.
fastvee
  • budget builder
« Reply #47 on: September 17, 2016, 08:52:02 am »
Last run of the season
https://www.youtube.com/watch?v=veLDws6bc24&feature=youtu.be
51mm plastic props, 76kph
martno1fan
« Reply #48 on: September 17, 2016, 01:23:07 pm »
Nice video ,she still wants to get airborne maybe a touch down angle on the props needed.Did you change the cog forward yet or not Pate.
Video makes me wanna build one for me lol ,i have two brand new 4092 1600 kv inrunners i could try.
Saw a guy using similar motors in a Conquest cat and she went quite well .
https://www.youtube.com/watch?v=ZQjqpdpdFNI&list=FLBvMrXd-byRavNCBWuCxqHg
fastvee
  • budget builder
« Reply #49 on: September 27, 2016, 01:05:11 pm »
Mart, I did move the batts all the way forward(completely under deck now) ,also removed the rx pack and used the escīs bec so that moved the cog a bit back .
Thinking inward props is again what makes it a bit floaty.
The boat is in winter storage now, next test in the summer 2017!
holy crapola that conquest moves!
Pages: 1 [2] 3   Go Up
