Author Topic: Motor Mounts  (Read 3601 times)
boat captain
Motor Mounts
« on: September 02, 2013, 09:19:42 am »
Hi
Does anybody know of stockists of water cooled motor mounts to fit out runner with 16mm pitch mounting holes.
In anticipation
Joe :-)) :-)) :-))
Joe
Liverpool MBC Committee Member
Islander51
Re: Motor Mounts
« Reply #1 on: September 03, 2013, 08:21:51 am »
exvtop
Re: Motor Mounts
« Reply #2 on: September 03, 2013, 08:47:03 am »
Or eBay uk
Search item number 360728332729
boat captain
Re: Motor Mounts
« Reply #3 on: September 03, 2013, 10:04:34 am »
Thanks exvtop item is for 540 size motors his 380 ones are out of stock and have been for quite a while.
Thanks Islander 51 Cornwall are out of stock also.
I have been trying to get them for about 6 weeks now tried from China etc and they have always been 540 size when they arrived.
Joe
Joe
Islander51
boat captain
Re: Motor Mounts
« Reply #5 on: September 03, 2013, 11:35:52 am »
Hi Islander51
Like the others they are out of stock.
Joe
Joe
Islander51
boat captain
Re: Motor Mounts
« Reply #7 on: September 03, 2013, 12:05:41 pm »
Hi Islander51
I need the 380 size the boat I am building is twin screw the bigger mounts are two wide to fit in.
Joe
Islander51
Re: Motor Mounts
« Reply #8 on: September 03, 2013, 03:15:03 pm »
Even Astec are out of stock, but you could ring them to see if they know when some might be coming in.
boat captain
Re: Motor Mounts
« Reply #9 on: September 03, 2013, 04:16:27 pm »
I rang them and a while ago also Prestwich model boats both said a couple of weeks.  I check their websites every day.
Thanks for your help.
Joe
Joe
irishcarguy
Re: Motor Mounts
« Reply #11 on: September 05, 2013, 10:52:27 pm »
They are easy to make  from brass or Ali & you can make them exactly the way you want them. Mick B.
Mick B.
boat captain
Re: Motor Mounts
« Reply #12 on: September 06, 2013, 08:50:12 am »
I am after water cooled mounts .   Ordered some from Cornwall Models hopefully these are the right size after 3 previous orders from different suppliers. Will update you all.
Joe
Joe
pompebled
Re: Motor Mounts
« Reply #13 on: September 06, 2013, 11:24:16 am »
Hi Joe,
I think what Mick B means, is that a watercooled mount can me made too, either from brass or aluminium, I've done both.
In brass:
And in aluminium:
And added later to an existing mount:
Regards, Jan.
Boaters are nice people
Subculture
    • Dive-in to Model submarines
Re: Motor Mounts
« Reply #14 on: September 06, 2013, 12:00:33 pm »
Aluminium will be a better heat conductor than brass. This surprised me. Some years ago I made a watercooling system for my computer, and I used copper plate for the heatsinks, which is the best metallic heat conductor unless you start messing with precious metals, but was surprised to discover in my research that brass is rather a poor heat conductor.
I'm sure either will be an improvement on air cooling though.
