Author Topic: model slipway trent 1/16th window frames  (Read 3017 times)
luke1993
« on: October 04, 2013, 06:51:01 pm »
hi
obtained a model slipway trent is quite old and the glazing in the windows is yellowish and quite brittle.
I was hoping to get a set of trent window frames from somewhere so I can glaze them and replace them as I think the originals may get broke
removing the glazing as its quite thick.
Is there anywhere you can buy the window frames in 1 16th I know macsmouldings do 1/12th  frames
many thanks in advance
stuart22
Re: model slipway trent 1/16th window frames
« Reply #1 on: October 05, 2013, 11:29:49 am »
Hi Luke Speedline do a set and are more to scale, i put them on the Trent which was given to me by a member from my club, they do look better than the kit ones.
be prepared for the price.
luke1993
« Reply #2 on: October 05, 2013, 12:33:21 pm »
yes I just looked £85  a set have to save I think
cheers
luke1993
« Reply #3 on: October 05, 2013, 12:48:13 pm »
stuart pm sent
pipster
« Reply #4 on: October 05, 2013, 06:23:52 pm »
Luke,
I have the Speedline windows on my MS Trent and they are very good but as you've discovered not cheap.
Just a note of caution though about retro fitting to a finished model; mine were slightly bigger than the openings in the kit.  So enlarging the openings may be necessary and on yours and you'd need to clear the debris from inside a sealed wheelhouse.
Phil
stuart22
« Reply #5 on: October 06, 2013, 09:09:07 pm »
Also on the front windows, the openings are to large so you have to fill in. I used plasticard it did work well, so don't be put off with what has to be done. :-))
