Author Topic: Ok what am i doing wrong??  (Read 10262 times)
portside II
  • tugs at rest
Re: Ok what am i doing wrong??
« Reply #25 on: June 19, 2007, 09:02:47 am »
thanks bob ,i have been down that route allready with Bryan  from m.m.m. and he cannot get that type any more as he has moved onto the new T motors ,
and at £45. each i just cant justify the purchase ,yet.
on a possible up side there is an advert in this months M.B. for a pair of 555's which are worth a try (page 77) .and they should fit directly in the mounts i have .
What would you think about the speed 700 turbo bb's , maybe a bit too fast??
daz
« Reply #26 on: June 19, 2007, 09:36:31 am »
portside II
I have a mate who uses 700 BB Turbos in scratch built 4 feet fast launches.
They plane well!!
In yours they will give fast electrics a good run!!
There are other motors that would do, in fact Model Motors Direct specialise in multi-pole low rpm, low drain motors.
I must admit that Car Blower motors do seem rather overkill for 40mm props.
You could try the Model Slipway geared motors for the Aziz.
2 x Motors for 12 volt £53-00.
With decent brass props you don't want to go above about 5000 rpm, that will give you plenty of power.
Out of interest did you run her on the Johnson motors?
portside II
  • tugs at rest
« Reply #27 on: June 19, 2007, 03:37:49 pm »
no the first thing this morning i whipped them out and put them to one side on the "dont go there" shelf i also have a pair of mfa como motors on the way f.o.c free of charge ,from a friend ex stock ,i think they are 540-1 so i will see which work the best ,them or the ones from m.m.d.
i will try them some time in the future possibly in a large hull fishing boat i have (gm33) from models by design ,but thats another project for the future .
daz
« Reply #28 on: June 19, 2007, 04:00:56 pm »
Just a quick thought.
Lots of modellers get caught up in the size and weight of the model.
I only consider the driveline, the motor and prop combination.
As a rule of thumb, most scale models will perform OK with Deccaperm Motors. THESE REV AT ABOUT 2750 RPM.
550 MOTORS ON A 3:1 reduction g/box will rev at just over 3000 rpm and a lot cheaper.
There is always an alternative!!
portside II
  • tugs at rest
« Reply #29 on: June 19, 2007, 06:19:05 pm »
never realy looked at Deccaperm motors or any other type of geared motors Bob as i dont like the sound they make ,thats just me  i have a southampton RTR and it has geared motors and i think they sound horrible  :P.but thats my opinion  :) also our chaiman has a large tug with geared motors and i think they are Deccaperm .
daz
« Reply #30 on: June 19, 2007, 08:32:50 pm »
Graupner do some big slow revving motors, but about £40-00 a time!!
Your best bet is Model Motors Direct, but not 555's or 777's
kendalboatsman
« Reply #31 on: June 19, 2007, 09:59:11 pm »
These motors
     http://cgi.ebay.co.uk/Johnson-6-12v-Motor-New-Ideal-For-Model-Boats_W0QQitemZ250130817277QQihZ015QQcategoryZ140972QQrdZ1QQcmdZViewItem
I just looked at those johnsons motors on ebay and they look to me like the motors fitted to cordless drills (used to have to repair the bloomin' things). Best left well alone in model boats.
Clive :)
Ian Robins
« Reply #32 on: June 19, 2007, 11:01:56 pm »
One of our members goes to the local breakers yard and he has found that Rover heater blower motors are easy to get off, cheap and are very powerful.
The motor amps are low as well on 12V
These motors look much like the MMM motors that I saw on the stand at the IMS at Leamington spa.
He also only pays approx £5 each so one trip gives half a dozen or so motors.
Good luck
ro88o
portside II
  • tugs at rest
« Reply #33 on: June 20, 2007, 09:41:53 am »
Cheers ro88o
i am off down to the scrap yard on fridayto see what i can salvage as the rear wash motors are suposed to be good ,just require the gear teeth removing.
Bob what's wrong with the 777,555 motors :o
daz
« Reply #34 on: June 20, 2007, 10:26:35 am »
Nothing wrong with them.
I have 2x 777's in my Schultze Class Minesweeper.
On 6 volts underpowered, on 12 overpowered, and running on 35 mm props, plus they get quite warm.
I gotta say though car gear rather heavy for turning 40 mm props, I prefer them on 50mm plus on direct drive.
portside II
  • tugs at rest
« Reply #35 on: June 20, 2007, 02:59:28 pm »
that's OK then ,i have a pair on order from model motors direct (555's) after reading the article in this months M.B
 and the props on nangee are 50mm 4 bladed brass raboche??
when thy arrive i will post some running comparisons with them ,the MFA 540's and the wash wipe motors to Se which ones fair the best .
And i am in the process of fitting a pair of electronise esc's to run them separately.
daz
portside II
  • tugs at rest
« Reply #36 on: June 21, 2007, 06:21:22 pm »
the mda 540's are in ,maplins are quick only ordered them tuesday afternoon.
had a quick test in the tank and all looks fine on 2x12v,2x esc's into one channel ,a propper dip at the weekend .
daz
« Reply #37 on: June 21, 2007, 10:38:44 pm »
Hope they are ok, post the results Daz.
1 question though, are the 540's rated for 12v, as most are for 7.2v?
DaveB
« Reply #38 on: June 21, 2007, 10:41:02 pm »
I fitted 555 motors from Model Motors Direct in Graemsay a couple of years ago on 12v and was very impressed good turn of speed and run time, i restocked at Alfold the other week and brought some Buhler ppb2's as well. I've been fitting buhlers for some time and never had any problems as Brian at MMM says its better to have a big lazy motor than a small high revving one.
Dave B
« Reply #39 on: June 21, 2007, 10:41:57 pm »
Couldnt agree more Dave.
portside II
  • tugs at rest
« Reply #40 on: June 22, 2007, 12:05:16 am »
hi Bob
the 540's are rated 7.2v - 15v and recomended at 12v so they should be ok .
i will second thet on too DaveB  though not tried the buhler motors
Page created in 0.169 seconds with 18 queries.
