Pages: [1] 2 3 4   Go Down
Author Topic: Mobile Marine Semi Scale Tug Arlin  (Read 27378 times)
Stan
« on: December 10, 2013, 07:49:46 pm »
Hi Guys I have just started to build this semi scale tug for junior family member hull is fitted out just needs fine tuning then upper deck section can fitted in place. I have included some pictures hope you enjoy
Stan
Re: Mobile Marine Semi Scale Tug Arlin
« Reply #1 on: December 10, 2013, 07:52:10 pm »
More pictures
Stan
« Reply #2 on: December 10, 2013, 07:57:46 pm »
Final pictures. I  have tried to load the pictures in one group but for some reason it would not let me sorry.
Stan.
« Reply #3 on: December 10, 2013, 08:38:39 pm »
Looks good Stan
How old is Junior? ... Good excuse for a build too.
Currently I am knocking up a castle for a five year old. It started with simply buying (ouch) ten mixed Knights ... And then I thought ... And now I am being creative. I could do with some flags or pennants and I might get some horses. I might even get carried away and get him a Welsh Dragon.
Stan
« Reply #4 on: December 10, 2013, 09:43:04 pm »
Having to build this boat for junior number two. Junior one sails is with granddad. Junior two keeps asking when will mine be ready under pressure or what. Still trying to finish the minesweeper. {:-{ {:-{ {:-{ {:-{ {:-{ {:-{
« Reply #5 on: December 11, 2013, 04:26:48 am »
Junior 2 sounds like the right kind of pressure and a better priority all round.
Stan
« Reply #6 on: December 11, 2013, 04:40:17 pm »
HI all today I have checked out all the functions in the hull altered the rudder push rod checked the light switch was working on channel 5 of the radio. Also today I have tidied up the openings in the deck section to make sure everything can be got to when the deck is glued in place. I need to grease the prop shaft then one final dunk in the bath to confirm no leaks after which the deck will be fixed in place. I have loaded some more pictures to show openings in the deck section and the various equipment that are in these spaces.
Stan
Stan
« Reply #7 on: December 11, 2013, 04:41:29 pm »
More pictures
Stan
« Reply #8 on: December 13, 2013, 06:24:37 pm »
Prop shaft  greased now in the test tank to prove no leaks. If all is o/k deck will be fixed in place Saturday afternoon.
Stan.
Kirklees Model Boat Club. :-)) :-)) :-))
eddiesolo
« Reply #9 on: December 13, 2013, 09:07:46 pm »
Looking good there Stan, again up to your excellent standards.
Si:)
« Reply #10 on: December 14, 2013, 11:40:57 am »
That looks a work of art Stan.     :-))     :-))
Stan
« Reply #11 on: December 22, 2013, 01:13:16 pm »
Hi Everyone managed to glue the deck on yesterday. I used a ton of stabalit express but this will give a strong joint all round. I used the brick to hold down the hull until the glue  had dried. I now need to rub down the joint line to get a smooth finish more picture to follow after the Bank Holiday. Happy Christmas everyone I hope Santa brings you all something model related.
Stan. :-))
Stan
« Reply #12 on: December 22, 2013, 01:14:20 pm »
Last picture showing joint line.
Stan
« Reply #13 on: December 24, 2013, 08:52:30 pm »
Hi Everyone hope you are ready for the big day tomorrow. I have managed to sand down the joint line today and the hull is now ready for some more holes to be drilled in it. We can then start on the superstructure. More pictures to follow in the new year workshop shut down until early January.
All the best everyone.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-))
Stan
« Reply #14 on: December 30, 2013, 06:24:55 pm »
Just started to add a little more detail to the hull to give a scale look. Areas marked out then drilled and finished with files. The openings will need to be lined with thin plastic card to finish them off and make them watertight. I intend to fit small plastic strips on the outside to follow opening profile of the wash ports. More to follow.
Stan
« Reply #15 on: January 04, 2014, 06:42:57 pm »
Just started to fill wash port holes with thin plastic card. I have removed the vac formed section where the bridge is located and fitted new coamings  so new bridge unit can be built.
Stan
« Reply #16 on: January 04, 2014, 06:46:01 pm »
More pictures. I intend to build a totally different superstructure for this semi scale model.
Stan
Stan
« Reply #17 on: January 05, 2014, 06:32:10 pm »
Been to the local timber yard today had a rummage in the scrap box came away with nice piece of MDF board. I have made a nice jig to hold the hull level during construction just a few pictures enjoy. I hope to do more on the minesweeper this week also. :-))
« Reply #18 on: January 06, 2014, 08:19:28 pm »
That's a lot spirit levels Stan.    hic  %)
Ken
mikearace
« Reply #19 on: January 06, 2014, 08:44:43 pm »
well see your keeping your spirits up Stan despite the build adversity!!
.........never trust a hippie
Stan
« Reply #20 on: January 18, 2014, 09:00:51 pm »
Just started to do some more. Working on the centre section at the moment a case of  trial and error but we will get there in the end.
Stan
« Reply #21 on: January 25, 2014, 04:59:26 pm »
Hi everyone. I have managed to do some more on the bridge section today. The original vac forming was not used I have decided to build my own design enjoy.
Stan.
Stan
« Reply #22 on: January 25, 2014, 05:01:30 pm »
last pictures
« Reply #23 on: January 25, 2014, 08:36:22 pm »
That brass work is as it should be Stan...... :-)) straight & square.......... all very important in the final image  O0.....Derek
Stan
« Reply #24 on: February 02, 2014, 03:39:26 pm »
Hi all I have managed to do a bit more this week. Upper deck section ready for widows to be cut and mast to make various hand rails fitted. Some towing points also added more to follow next week.
Stan
Pages: [1] 2 3 4   Go Up
