Author Topic: rnli severn class 2.4ghz boat  (Read 2039 times)
redsquirrel
« on: January 04, 2014, 11:10:48 am »
just a quick query,does anybody else have this little oddity?
when both tx and rx are switched on,if i use the forward,reverse stick first,then apply left/right,the boat works fine.
if i push the left/right on its own,the boat goes forward and backwards with both props running the same.
seems a bit odd,just wondered if it was a normal characteristic,cheers
this is the model i bought recently in the rnli shop at falmouth.
TheLongBuild
  • Build em, and play hard..
Re: rnli severn class 2.4ghz boat
« Reply #1 on: January 04, 2014, 12:06:23 pm »
Yes I have it, Yes it basically  turns on it on access using the left or right on its own.  Props are a left and right type.  Tested it at beyond its range with no probs ( Mind you no other boats on the pond at the time), could do with a tad more speed.
redsquirrel
« Reply #2 on: January 04, 2014, 09:32:10 pm »
cheers TLB, im expecting it not to last too long before modification needed but want to try it standard first
TheLongBuild
« Reply #3 on: January 04, 2014, 10:37:01 pm »
Likewise , it is my sons Christmas present  8)
Page created in 0.166 seconds with 17 queries.
