Author Topic: Rudder play  (Read 5265 times)
iantype-r
Rudder play
« on: February 23, 2014, 09:26:53 pm »
Hello all, I have the same setup as pictured below. The brass wire makes some play in the rudders. I don't like this and want to eliminate it, can anyone give me some ideas.
I have seen these, but I'm assuming once they are bolted to the arms they would lock, I need the top to turn as the rudder moves,
http://www.sourcingmap.com/pcs-linkage-rod-connectors-servo-horn-rc-car-plane-buggy-parts-p-427913.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle&gclid=CLbq05qX47wCFQUewwod6iMABg
tobyker
Re: Rudder play
« Reply #1 on: February 23, 2014, 10:08:03 pm »
You will get play in those as the brass wires are too flexible and will bow when they are in compression. If you don't want to go to the complexity of double (push-pull) linkages, I would get some fine tube and slip it over the brass wires - or just cut the bent ends off the wires and solder them into the ends of the tubes. The bowing will start in the middle of the links so you should be ok with the finer gauge wire at the ends.
Re: Rudder play
« Reply #2 on: February 23, 2014, 10:16:07 pm »
As Tobyker says, slip some close fitting brass tube over the wire which will make it much more rigid.
Skimmer Fan
Re: Rudder play
« Reply #3 on: February 23, 2014, 10:30:01 pm »
I have used something similar from my local R/C model shop sells aeroplane spares. I also used stronger larger stainless steel rods.
I used two nuts, the first one I tightened up until it was just giving me movement then tightend another nut up to the first nut using it as a locknut. I also put a small amount of Loctight thread lock in the second nut. Seems to work ok for me.
Skimmer Fan
NFMike
    • Plague Marine Services
Re: Rudder play
« Reply #4 on: February 23, 2014, 11:39:55 pm »
The black plastic ends have metal globes in them that are bolted to the various arms/wheel. No play.
Re: Rudder play
« Reply #5 on: February 24, 2014, 01:51:43 pm »
http://www.shgmodels.com/acatalog/2013cat.pdf
Page 29, lots of ball link options.
Re: Rudder play
« Reply #6 on: February 24, 2014, 02:22:11 pm »
Many RC servo links need much stronger links than you would think!    O0
nemesis
Re: Rudder play
« Reply #7 on: February 24, 2014, 02:27:53 pm »
Hi, Well, that is my parallelogram theory up the spout, nemesis
boat captain
Re: Rudder play
« Reply #8 on: February 24, 2014, 02:56:14 pm »
I was told and read somewhere you should not use metal to metal connections on servos as they can cause interference to the receiver.
Joe
Joe
Liverpool MBC Committee Member
iantype-r
Re: Rudder play
« Reply #9 on: February 24, 2014, 03:27:33 pm »
Many thanks for all the replies, I will have read when I get home,
Ian
Re: Rudder play
« Reply #10 on: February 25, 2014, 09:21:50 am »
If plague's picture is being referred to, I see 2 separate parallelograms, one for each rudder.
Joe
That was probably prop shafts.
inertia
Re: Rudder play
« Reply #11 on: February 25, 2014, 09:55:58 am »
Joe
FM receivers are said to be somewhat prone to interference from metal-to-metal electrical "noise" (such as the type of pushrod connection shown in the original post), but PCM receivers are fine. It's good practice to use plastic cup and brass ball links for pushrod to tiller connections as there is absolutely no slop at all in them.
DM
davidm1945
Re: Rudder play
« Reply #12 on: February 25, 2014, 10:22:23 pm »
I used the U shaped rib from a broken umbrella, cut to length and crimped in several places over the control rod, it won't bend now!
Page created in 0.152 seconds with 17 queries.
