Author Topic: hazelgarth  (Read 3441 times)
Grace2
hazelgarth
« on: March 11, 2014, 09:30:18 pm »
hi, has anyone got any photos of the model please, will be starting to rebuild the top side of mine soon and im after some ideas, when i cut the deck out of mine i found i didnt have enough room to fit the tiller arms for the kort nozzles so iv modified the hull to give me enough room............
Grace2
Re: hazelgarth
« Reply #1 on: March 11, 2014, 09:32:03 pm »
a couple more
Grace2
Re: hazelgarth
« Reply #2 on: March 20, 2014, 10:55:40 am »
heres the boat nearly finished,a big  thanks to stavros its now brushless and very powerful  :-)) ..there still alot of detail work to do..
Grace2
Re: hazelgarth
« Reply #3 on: March 20, 2014, 10:59:00 am »
mister cornishman
Re: hazelgarth
« Reply #4 on: March 20, 2014, 12:52:54 pm »
We NEED pics of the HOOLIGAN tug in ACTION  O0 O0 O0 O0 O0 O0 O0 O0 O0 O0 O0 O0
Grace2
Re: hazelgarth
« Reply #5 on: March 20, 2014, 06:57:32 pm »
i will say its got nice gentle progressive manners small/medium throttle openings.. quick shift into reverse it steers backwards loveiy, turns in its on length its almost sudate its very very calm on the sticks.............
get rough with it and on full rudder it burys the stern and spins on the spot, straight line from standing start it pushs the tug up onto the plane in less than 5 feet with rooster tails flying off the bow..this isnt a light weight tug..40" long..17 amp sla battery and 3 kilos of lead fibre glassed into the stern..all the weight is low down..iv put a 17kg servo on the steering. id made a great looking raised hatch to go into the back deck  so i could easily get into the back end.. iv had to go for a sealed deck and a remote operated bilge pump incase things get tricky........................
BEWARE........if you tell stavros you want mental power with nice mannered brushless motors this is what you get...motors and speed controllers came to £120 all in...............worth every penny   %) {-) :-))
Grace2
Re: hazelgarth
« Reply #6 on: March 22, 2014, 02:58:04 pm »
i managed to get the boat to do the bollard pull today, my fishing scales only go upto 25lbs and it pulled that all the way with plenty of power left so im go to have to borrow some bigger scales i guess..heres a few pics of her in the water
Grace2
Re: hazelgarth
« Reply #7 on: March 22, 2014, 02:59:46 pm »
wicker
Re: hazelgarth
« Reply #8 on: March 22, 2014, 04:00:03 pm »
That is not a tug thats a speedboat--you will have to give it something heavy to pull - Charlie
Grace2
Re: hazelgarth
« Reply #9 on: March 22, 2014, 04:02:56 pm »
thats the next project.......a decent sized barge...iv got a good number of the old 56lb patato weights knocking about  %)
Re: hazelgarth
« Reply #10 on: March 22, 2014, 09:23:50 pm »
WoW WoW you are a flipping HOOLIGAN I know you told me I NEED POWER my lord did I give you POWER
I honestly dont know what to say ME SPEECHLESS.......... :embarrassed: :embarrassed: {-) {-) {-) {-) {-)
Now we have got a Powerboat section I seriously think you should go RACING  O0 O0 O0 O0 O0 {-) {-) {-) {-) {-) {-) {-) {-)
Grace2
Re: hazelgarth
« Reply #11 on: March 22, 2014, 09:39:45 pm »
i dont normally thrash it like that  to be honest, i try to be accurate with it monovering. its very torquey..iv hopefully done a deal on a 2.3m barge so i can fill that with 56lb weights and drag that around.. :-))
Page created in 0.448 seconds with 17 queries.
