Author Topic: its my simple smoke unit...  (Read 7078 times)
Krishna
  • aqua plannerrrr....................
« on: May 07, 2014, 04:50:27 pm »
yes, smoke on boats and crafts brings so realism when it runs.. is not a new idea, but just completed for a new boat.. just a bellows from a kids bicycle.. and a servo converted to run continuos.. and two pooja stics, (incense stics) are placed inside the smoke tube, is HD PVC pipe.. and puff.. puff...
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
Krishna
Re: its my simple smoke unit...
« Reply #1 on: May 07, 2014, 04:53:19 pm »
« Reply #2 on: May 07, 2014, 06:53:12 pm »
brilliant idea...........ideal for a Scottish puffer. neil. :-)) :-))
Krishna
« Reply #3 on: May 08, 2014, 04:40:50 am »
yes Sir.. its fun.. and here is the craft...https://www.youtube.com/watch?v=kJokfpVMwBs
thank you..
marinemole
« Reply #4 on: May 08, 2014, 10:53:50 am »
Couldn't agree more. Well done and thanks for sharing.
Andy
« Reply #5 on: May 08, 2014, 11:10:10 am »
Incense sticks must smell better than baby oil  {-) {-) {-)
Terry
« Reply #6 on: May 08, 2014, 11:42:39 am »
So Ingenious, real "out of the box"  thinking.
Millertime
« Reply #7 on: May 09, 2014, 06:13:54 am »
That is cool.
Z750Jay
« Reply #8 on: May 09, 2014, 06:35:58 am »
Now if you could get steam or diesel scented sticks.........
slug
« Reply #9 on: May 10, 2014, 08:32:57 am »
try dipping joss sticks in derv,that when dried a bit may give the required smell...as an ex trucker the smell on clothes if spilt doesent wash out for ages.....might be worth a try....tony
« Reply #10 on: May 10, 2014, 09:42:59 am »
Might also burn a bit qicker %% %%
Krishna
« Reply #11 on: May 11, 2014, 06:09:47 am »
good morning.. thank you all of my loving Friends..
discovery man
« Reply #12 on: May 19, 2014, 08:23:17 pm »
hi its a realy good idea..
Krishna
« Reply #13 on: May 20, 2014, 03:50:39 am »
thank you..
« Reply #14 on: May 20, 2014, 09:27:37 am »
Great concept  :-))
spooksgone
« Reply #15 on: May 20, 2014, 04:05:42 pm »
Very clever, I like it :-))
Buccaneer
« Reply #16 on: May 20, 2014, 08:26:45 pm »
Great Idea. Need more smoke? - double up on the Incense sticks. I'm no inventor or scratch builder but couldn't a small fan unit be used, run off of the motor esc?
Krishna
« Reply #17 on: May 21, 2014, 10:12:48 am »
thank you Martin sir..
thank you spooksgone..
Buccaneer.. yes, can add more sticks for greater smoke.. can also add an aluminum mesh, inside to absorb and to radiate heat to a great extent, and instead of using a fan and one other ESC, we can use a spare servo, or a servo unsued, or a servo with damaged gears, as taking out its motor and printed circuit board, while removing the potentio meter, and adding two 2.7 kilo ohms resistor, so we can make a simple blower with foam board, and the blower can fitted with the motor of the servo.. so, by connecting the servo to a desired channel, can run, adjust the speed, or can make puffing action by switching on it and off.. with the power from the RX itself.. thank you..
discovery man
« Reply #18 on: May 24, 2014, 09:56:53 pm »
hi iv been thinking about your smoke machine..as iv already stated its brilliant...im thinking about it/making one...but using a small fan out of a old pc/12 volt one...but then it could be too much/wind...............
Krishna
« Reply #19 on: May 25, 2014, 06:30:44 am »
Sir, its easy to add a fan for blowing the smoke.. a 12 Volts DC PC fan will be big one, mostly in to 4 inches.. and yes will be great flow.. you can add a flap door just under the opening of the fan.. so can adjust the opening, so can adjust the flow.. more easily, you can make a centrifugal blower, made of foam board, driven by a toy motor, can add to any craft, will be compact.. as the toy motor runs at 1.5 volts.. will be easy and so compact.. you can also add a driving circuit to the motor, so can switch it on and off, and can control the on + off times by turning a potentiometer, and can add this potentiometer to the throttle channel, so can increase or decrease the rate related to throttle..
and above all, you can use a motor directly from a servo.. as a blower fan..
here added a motorized centrifugal blower with a toy motor.. the plastic bottle acts as the smoke pit here.. and a silicon tube for delivery..
« Reply #20 on: May 26, 2014, 04:49:23 pm »
Very clever idea, congratulations, I am going to have a go and making one, will post some photo's when I have done  :-))
Krishna
« Reply #21 on: June 15, 2014, 07:31:50 am »
thank you Sir.. its nice..
