Author Topic: Water-cooling jackets  (Read 3104 times)
me3
« on: July 09, 2014, 01:59:12 pm »
Hi all,
I have this motor in the picture - its water cooling jacket is blocked, not sure by what though {-) Does anyone know what they are like inside? Do they have channels in that work along the motor, also any idea how I could get it off?
Thanks Reece
U-33
  • K-157 Vepr. Akula-11
Re: Water-cooling jackets
« Reply #1 on: July 09, 2014, 02:13:55 pm »
Pop down to your local garage  and give it a blast through with an air line, that'll sort it out.
« Reply #2 on: July 09, 2014, 05:21:16 pm »
Try squirting some Cilit Bang down it they advertise that is clears limescale so maybee it will clear your blockage or even Bicarb of soda
« Reply #3 on: July 09, 2014, 10:49:16 pm »
Reece...tend to agree with Stavros....look at the whitish scale build up on the inlet & discharge hose ferrules
1. support the motor with the shaft vertically down.....insert a piece of clear silicone tubing to the lower hose ferrule...fill up with CLR [anti scale...for calcium. lime + rust] until it overflows from the top ferrule  %)
2. let it sit there for 24 hours.......flush out & repeat if necessary
3. if this does resolve the issue....maybe consider a 1/2 litre flush of fresh water by the pool side after each run just by a plastic squeegee bottle connected to the suction side :-)).....
w3bby
« Reply #4 on: July 09, 2014, 10:56:56 pm »
Blow it through with 5-56 orWD 40 at the end of the day to clear the water out. I run on brackish water and it clears all the salt and prevents corrosion..
me3
« Reply #5 on: July 09, 2014, 11:06:34 pm »
Thanks for the advice everyone. I managed to get to the jacket off. The holes in the jacket were completely blocked. It has spent all day with limescale stuff in. Anyway all gone now. I do always flush my models, however this is from a boat I found :-)
TheLongBuild
  • Build em, and play hard..
« Reply #6 on: July 09, 2014, 11:30:56 pm »
How did the jacket come off ?, Could be useful to know.
me3
« Reply #7 on: July 10, 2014, 08:40:56 am »
It just slides off with a bit of force. A member told me on a PM, it's only sealed with an 'o' ring at each end! Excuse the image quality  :embarrassed:
« Reply #8 on: July 10, 2014, 11:50:20 am »
OK Reece
1. you now need to re preserve both the OD of the motor casing and the ID if the cooling jacket
2. I assume the motor is a steel cage & and the cooling jacket an aluminium enclosure
Lets ask Stavros for a few comments here on the best way to preserve the different metals & still maintain a case dimension that will be OK for the o-ring sealing diameter  :-))
me3
« Reply #9 on: July 10, 2014, 12:40:52 pm »
Yes, thanks, that is correct I believe, though the motor case could be aluminium, I think! I was just going to spray them with black gloss or something to stop any extra corrosion.
Reece
