Author Topic: Speed controller  (Read 3413 times)
macdaf426
  • mac
  • back to modelling after long absent
Speed controller
« on: July 14, 2014, 05:26:08 pm »
Hi can any one advice me, I have a Tornado 50a controller it worked at home got to the pond and the motors would not work, all other servos are working and the motors will work direct with battery. Can I test the controller, Thanks, Mac.
mac from Penzance
Time Bandit
Re: Speed controller
« Reply #1 on: July 14, 2014, 06:02:31 pm »
Did you check the reciever? Change plug from ESC to one port where the servo works.
What kind of battery are you using?
Some ESC shut down the motor if the voltage is too low, I don´t believe this one to have lipo-cut off but maybe the battery fell below 6V?
You can also measure the output voltage with a simple multimeter.
Any possibility to reset the controller and program it newly?
regards
Tobias
Robert Davies
« Reply #2 on: July 14, 2014, 06:17:03 pm »
The quick 'n' dirty technique advised by an old school auto elec….
With it all setup ready to go…
Wiggle each wire one by one in turn.
Moving on from there, I assume that you do not have a separate battery for the receiver, and consequently because the servos are functioning, the motor connecting wires and any joints connections therein are now suspect - check and remake those joints or connections - and now retest the setup for function.
Bear in mind that these Tornado controllers are not of the highest quality, and pretty much the only QC is you the customer - their 50A rating does seem wildly optimistic compared to much lower ratings from Electronize and Mtroniks.
inertia
« Reply #3 on: July 14, 2014, 07:27:42 pm »
Chinese amps are much smaller and compact, Rob. 8)
Dave M
John W E
  • I see no ships !!
« Reply #4 on: July 14, 2014, 08:09:04 pm »
Hi all
Quick check on this website about the speed controller
http://www.amazon.co.uk/Tornado-50amp-Controller-Remote-Control/dp/B00438ARVC
it seems that if this is the speed controller we are referring to - it closes the power off to the main motors; if the main battery power drops too low.
So I wonder, beforehand, did you leave the power on before you arrived at the actual lake?
aye
john
Knowledge begins with respect
macdaf426
  • mac
« Reply #5 on: July 14, 2014, 10:36:15 pm »
Thanks for your replies, it was a fully charged battery, so I dont understand what is wrong I have tried it again today all else is working but still no motors .
mac from Penzance
Robert Davies
« Reply #6 on: July 14, 2014, 10:47:20 pm »
You did do the wiggle check, Yes?
A photo of the installation may help us to help you, here.
Page created in 0.354 seconds with 18 queries.
