Author Topic: Futaba FF7 conversion to 2.4 ghz ?  (Read 4708 times)
phillnjack2
« on: July 22, 2014, 08:25:45 pm »
I have heard that simply by buying a new module that just replaces the one on the back of my old futaba FF7 can give me a full 2.4ghz transmitter ?
I would be buying the receiver to go with the module at same time that is compatible but wondered if there is any problems in doing such a thing.
This would allow me to have my well proven and trusty radio for marine use without getting any interference.
and would this give me a decent range ? if so how much  on water ?
or is a new cheap plastic 2.4ghz set just as good as my old futaba ?
phill
w3bby
Re: Futaba FF7 conversion to 2.4 ghz ?
« Reply #1 on: July 23, 2014, 09:29:45 am »
You've asked this before....
Modern radios come with failsafe functions for loss of signal, low battery etc. Use of these can prevent a runaway boat but you will need to be prepared to retrieve a dead boat from the water.
phillnjack2
« Reply #2 on: July 23, 2014, 01:38:10 pm »
yes I did ask this a long time ago, and forgot the answers to it. (that's why I asked again !!!! :P )
I fit my own fail safes to my boats and never worried about a dead boat in the water as I am in my speedboat with it 99% of the time.
I have seen some pretty cheap modules from a few different makers, and wondered what are good and what are bad.
I would buy a genuine futaba  if I find a cheap one used. Futaba prices are far too much for stuff they don't even make.
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #3 on: July 23, 2014, 02:08:24 pm »
The FF7 does not have a replaceable module, so you will need a hack module. I don't think Futaba make any hack modules.
I converted a FF7 to 2.4ghz, pictures at the bottom of this thread
http://www.modelboatmayhem.co.uk/forum/index.php/topic,24085.0.html
Check out the cost of receivers as well, they are normally specific to which 2.4GHz system you are using.
Subculture
    • Dive-in to Model submarines
« Reply #4 on: July 23, 2014, 02:13:26 pm »
A few years ago, it was worth doing. Now, unless you have a radio which you're really fond of and/or has some unique capabilities you wish to retain I wouldn't bother.
I would go with Spektrum/Orange based gear. It's the closest you can get to a standard with 2.4ghz, and there is a huge range of receivers at very competitive prices.
phillnjack2
« Reply #5 on: July 23, 2014, 02:39:21 pm »
sorry mankster
 but the pics you refer to are not of a field force 7 like mine.
I think your mistaking what a real FF7 is ?
mine does have a plug in module on the back
here is the original FF7 from futaba, and no the colour is not wrong, its a metal look bronze finnish.
Mankster
  • Wheelerdealer
« Reply #6 on: July 23, 2014, 04:32:34 pm »
Ops, got carried away... :embarrassed:
tsenecal
« Reply #7 on: July 27, 2014, 05:48:00 pm »
phillnjack2,
i have several of the FF7's bigger brother the 9cap , and i have owned the 7uap, and 8uap (the US name for the FF7, and what i assume would be the FF8 )
all use the same module for the RF deck.
I have purchased and highly recommend the Assan module and receivers.  i have several (almost a dozen) of the Assan 6 and 7 channel receivers.  one nice thing about them is that they have their own built in failsafe setup.
they can be found at most chinese websites including HobbyKing.
Page created in 0.644 seconds with 18 queries.
