Author Topic: Strip lights  (Read 2509 times)
spooksgone
Strip lights
« on: August 07, 2014, 10:20:52 am »
Hi all. I seem to spend ages working on bits and bobs which look good in the work shop, but when I take them out in too day light, I can see a lot of faults :(( Is it my eyes just getting old, or should I have another sort of strip light above my work bench? Having said that, not sure what sort I have any way. Any ideas?
Cheers all.
Phil
inertia
Re: Strip lights
« Reply #1 on: August 07, 2014, 10:31:51 am »
Phil
Cheapest option is to swap the standard tube in your fitting for a daylight tube. Next up would be to buy a desk lamp with one or two 11W daylight tubes in it (have a look at CPC's website). These are much easier on the eyes for working than standard tubes although you still get the 50Hz flicker.
My top-of-the-range solution, when I fitted out my new workshop, was square LED lighting panels on the ceiling. I have 8 of them, each around 300mm square and powered from the mains via 24v transformers. I only use four most of the time (those over the bench). Cheap they ain't but wonderful they am.
Dave M
spooksgone
Re: Strip lights
« Reply #2 on: August 07, 2014, 10:55:54 am »
Once again, I thank you Dave. You are a mind of information. Your work shop looks fantastic, I just got a corner of the garage, I still enjoy being in it though :-) I will post a pic or two later on the progress so far on HMS Woodcock. Thank you again Dave.
Phil
NFMike
Re: Strip lights
« Reply #3 on: August 07, 2014, 01:20:11 pm »
Cheers all.
Phil
I don't know how old you are but, yes, you need more light as you get older. The data is hard to distill as people differ a lot, but I'd say as a rule of thumb by the time you retire you should be trying to get about twice the light on your task as you had when half that age.
My workbench now has 4x 25W daylight compact fluorescents in a white box about 2ft above it - probably about 400W tunsten equivalent. I made it to be able to switch just two on, but I never do that - it's nicer with all four.
Bear in mind that even then your lighting level will be measured in 100s of whatever, whereas outdoors is in 1000s, so it is always hard to see the true end result until you take it outside.
As Dave says, daylight lamps are going to be best in virtually all ways, and especially for painting.
spooksgone
Re: Strip lights
« Reply #4 on: August 08, 2014, 07:59:39 pm »
Thank you for the info plague. I have switched my old tube for a natural day light one now, and can see the change straight away. Hope fully this will now save time. Thank you one again.
Phil [aged 55]
