Author Topic: MDF Workbench - help please  (Read 10771 times)
spike
« on: September 15, 2014, 09:55:13 am »
at is best stuff to use on mdf please i am using it fo my bench top thanks
Seaspray
Re: help please
« Reply #1 on: September 15, 2014, 10:06:54 am »
Don't like MDF If gets wets it falls apart. You may try 5 coats of oil based outside varnish if you're doing light work and it won't get wet . I put it on chipboard flooring so far it's holding up.
No chance of something stronger like ply or better still an old worktop?
Re: help please
« Reply #2 on: September 15, 2014, 10:08:16 am »
I would give it several coats of varnish to protect the surface from stains etc. Preferably satin or matt. Gloss would probably be a little slippy. Don't forget to rub down between coats.
Re: help please
« Reply #3 on: September 15, 2014, 10:15:29 am »
Apart from the advice above, (you will definitely need to really seal the MDF well against spillage), I buy sheets of white faced hardboard to lie on my worktop. When they get scarred. stained and damaged I just replace them.
wingaard
Re: MDF Workbench - help please
« Reply #5 on: October 03, 2014, 09:31:27 pm »
Buffalo Ply is often used for engineers work-bench tops.
http://www.advancedtechnicalpanels.co.uk/products/buffalo-board-birch-plywood
« Reply #6 on: October 20, 2014, 09:16:47 pm »
this stuff is good on MDF.... I painted my shelving units with it as well as the shed floor
http://www.ronseal.co.uk/products/diamond-hard-floor-paint
RAAArtyGunner
« Reply #7 on: October 20, 2014, 09:39:40 pm »
Have you considered covering it with a laminate, known as Laminex, Formica, etc here in OZ.
Which in essence is compressed cardboard but hardwearing, available in non slip, cleans up well, eg, kitchen bench tops.
tr7v8
« Reply #8 on: October 20, 2014, 10:00:42 pm »
mine have always been kitchen work surface, very often able to get a damaged one for sensible money.
Jim
« Reply #9 on: May 19, 2015, 08:35:12 pm »
Often builders merchants like Covers will have offcuts of kitchen worktop 'in the back' for sale. I bought a piece a few years back for a reasonable price.
kinmel
« Reply #10 on: May 19, 2015, 09:17:25 pm »
I  always just leave the MDF bare, once it is truly ruined I just replace it with a new one.
« Reply #11 on: May 20, 2015, 02:19:43 am »
Merging what Kinmel and Colin have suggested. I have a sacrificial surface on top of my bench. You can use another piece of thin mdf or hardboard.When it is ruined, throw it away.
