Author Topic: Graupner MC 20 40mhz  (Read 4005 times)
destroyer42
« on: October 19, 2014, 08:42:06 pm »
Hi Has any member got an instruction manual for a Graupner MC20 40mhz TX ?
Destroyer42
klz
Re: Graupner MC 20 40mhz
« Reply #1 on: October 19, 2014, 11:34:10 pm »
Hi, is this what you are looking for.
http://tinyurl.com/lw8hshv
KLZ
inertia
« Reply #2 on: October 20, 2014, 08:53:40 am »
332 pages??!!!!Good luck with that, Colin!  {-)
DM
destroyer42
« Reply #3 on: October 20, 2014, 12:13:57 pm »
Hi KLZ,
Unfortunatly it's not the graupner HOTTE system it's the older TX MC 20 40mhz.
Destroyer42
klz
« Reply #4 on: October 20, 2014, 12:22:02 pm »
The only other one I can find is this one.
http://tinyurl.com/mtcfaoa
destroyer42
« Reply #5 on: October 20, 2014, 12:24:06 pm »
Hi Dave,
Thought I get this TX, that i got cheap so many buttons switches , but no instruction manual.
It's well made but not sure what it can do has two modules 35mhz & 40mhz with RX's.
One of my F14 has a problem, I dropped it and broke the arial bit that srews into the plastic, managed to fix it but the ariel not working correctly, servo's chatting, when i touch the ariel everything works fine any ideas?
inertia
« Reply #6 on: October 20, 2014, 01:06:38 pm »
I've just found that I have a copy of the MC22 (3D Rotary Programming System) manual which can't be all that different. If you remind me of your E-Mail address (by PM) then I can send it to you. It's 180 pages (nearly 4Gb) so there's no chance of attaching it here. At the risk of looking like a know-all you mustn't use the 35MHz module in a boat - it's very naughty.
Ref busted tranny, try Mike here http://www.modelradioworkshop.co.uk/  I've used his services before and he's an excellent bloke.
Dave M
« Reply #7 on: October 20, 2014, 08:31:40 pm »
Usually, the aerial screws into metal hidden deep inside the plastic, either through a tag to a captive nut, or a threaded bracket on the TX PCB.  It could be that it has just missed the metal (or a soldered on bracket got detached in the drop), and only gives a good signal when it is deflected a bit, like when the aerial is touched.  Or it could be that when you touch the aerial, you are suddenly the aerial.
Page created in 0.013 seconds with 18 queries.
