Author Topic: PB2  (Read 3899 times)
pipercub1772
PB2
« on: October 28, 2014, 03:29:17 pm »
Hi would anyone have any information on running a martin howes and baylis p b 2 steam engine I have gust got this engine and in all honesty it ,s not been run for a long time and was never cleaned before being stored  , it turned over very stif ,initally I gave it a good clean and a good oiling and ran it on air it needed about 40 / 50 psi to get it running but after about 6 ten minute runs with plenty of light oil  on all moving parts and in the air supply it seems to be running fine even down to about  5/10psi .so has anyone any information on general running on steam ie lubrication ,psi it should run at ,prop size, and potential model length I would be most grateful kind regards Allan
muleears
Re: PB2
« Reply #1 on: October 30, 2014, 08:12:46 am »
Here's a reply I got from pettyofficernick when I asked a lubrication question about my PMR 8M:
 "Hi Cal, fill the lubricator at the start of a run, when you top up gas, boiler etc, drain the condensate from the lubricator at the same time either with the drain cock at the bottom or with a syringe through the top where you fill it if it is awkward to gain access to the drain. 1 1/2 turns in the needle valve works fine for me ( the screw with the black rubber ring round it, and yes, it should move) Knowing when to fill the lubricator will become clear when you start to run the engine , just keep an eye on the oil level until you know how long it lasts. I usually get about 3 x 1/2 hour runs from one filling. Gas, water and oil consumption will become apparent once you get used to running the engine.
Nick. :-)) :-)) :-))"
This may not apply exactly to your engine but I thought it may give you some advice.  The above quote is from page 6 of my thread My Krick Victoria- MKII, if you want to read a little more about running the engine and breaking it in.  Hope this helps.
Cal
Washington, NC USA
Proud owner of:
75% complete Krick Victoria
75% complete Billing African Queen
Krick Alexandra
Lots of building, very little steaming!
pipercub1772
Re: PB2
« Reply #2 on: October 30, 2014, 09:16:03 pm »
Thanks for that I will follow that and give it a run on steam at the weekend regards Allan
AlexC
Re: PB2
« Reply #3 on: October 30, 2014, 11:53:58 pm »
Hi Allan,
Remember, you need to use steam oil in the displacement lubricator(cylinder lubrication) when running on steam... not car engine oil.
Steam oil grade 460 should be about right for that engine.
External moving parts and bearings can be lubricated with light machine oil. (20w)
Nice engine... take good care of it.
Best regards.
Sandy :-))
muleears
Re: PB2
« Reply #4 on: October 31, 2014, 02:27:06 am »
I'd like to see some pics or better yet a video of it running O0 .
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
pipercub1772
Re: PB2
« Reply #5 on: November 05, 2014, 01:50:36 pm »
Hi not had time to run on steam till Monday,hope you get the pictures I am trying to upload ,any idea of prop size regards Allan
pipercub1772
Re: PB2
« Reply #6 on: November 05, 2014, 04:08:54 pm »
Hi sorry i duplicated the pictures ,Allan
Duplicates removed.   (as will this message when you've read it)    :}    ken
Re: PB2
« Reply #7 on: November 05, 2014, 10:20:15 pm »
Alan.......that's appears to be an interesting steam regulator  :o
The linkage connection must need to be set very accurately as it appears to be designed for a start position of Zero steam/RPM ....then progressively moved in one direction to max steam/RPM,  but return the linkage arm to the start position then add negative movement will port inlet steam to exhaust  :embarrassed:
Or am I viewing this upside....being in OZ....... {-) ... or is it a method of blowing down boiler pressure remotely?.......Derek
steamboatmodel
Re: PB2
« Reply #8 on: November 06, 2014, 11:10:07 pm »
Alan,
Could you post some shots of the valve gear and linkage please.
Gerald
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
xrad
  • Keeper of the Sun Dried Tomato
Re: PB2
« Reply #9 on: November 07, 2014, 01:40:28 pm »
kick-starter arm for direction of rotation?  How does it disengage(by extending beyond radius teeth)?   cool engine.
pipercub1772
Re: PB2
« Reply #10 on: November 10, 2014, 08:04:54 pm »
Hi took video of engine running on steam today on my i pad, got it on to utube but it would not upload for some reason never done this before so it may be my lack of knowledge wish i was 17 not 70 ,however the engine ran really well no steam leeks reverses well and very powerful if you look at the second picture down you will see the regulator with the lever underneath for speed  a 1/4 turn needed from stop to full throttle, the lever to the front of the engine is the reversing lever this works well but i remember reading somewhere the engine should be st-oped before reversing so i did that there are 2 lubricators for steam oil and oil cups on crankshaft thanks for the interest ,regards Allan
Page created in 0.456 seconds with 17 queries.
