Author Topic: micro tug  (Read 7108 times)
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
micro tug
« on: November 01, 2014, 06:04:00 pm »
my new finished project . the micro tug based on the revel fairplay tug kit  at only 7 inches !
lets just hope this one floats !!
fire at will ! ... which one is will ?
radiojoe
Re: micro tug
« Reply #1 on: November 01, 2014, 06:42:00 pm »
Mwar Sweet.
tugnut
Re: micro tug
« Reply #2 on: November 01, 2014, 07:05:05 pm »
nice one  :-))   :-))
Re: micro tug
« Reply #3 on: November 01, 2014, 09:31:41 pm »
Me too, awesome!   O0
ian-mccaffrey
Re: micro tug
« Reply #4 on: November 01, 2014, 10:06:42 pm »
fully RC too . no rudders tho . its steered by the mixer in the hand set
Allnightin
Re: micro tug
« Reply #5 on: November 02, 2014, 01:11:45 pm »
What RC gear and motors are you using onboard?
ian-mccaffrey
Re: micro tug
« Reply #6 on: November 02, 2014, 02:56:40 pm »
using 2 standard servos chopped up to use for motors and the contoroll boards from them for esc's
Re: micro tug
« Reply #7 on: November 02, 2014, 03:03:42 pm »
Ian, could you explain to thicko's like me exactly what is in the box and how it works please........
I got the motors and the two boards from the servos stuck to the sides of the hull...........I see the pots ( in black that looK like switches) but how do they work from your radio.......and what is the circuit board between the two motors, could you explain in very simple things how they work as I would like to motorise an old Frogg Oakley class lifeboat I have at some stage as it is 1:48th, similar to my Calmac ferry............
but please simple terms.....ta.
ian-mccaffrey
Re: micro tug
« Reply #8 on: November 02, 2014, 04:13:03 pm »
Pots. When inside the servo turn with the gears and tells the brain where about the servo arm is
So basically you got to find the center point of the pot
Plug it in to the receiver with battery attached to it.  And turn it untill it stops. Then glue the moving bit of the pot. So it can never move again
And the circuit board you can see is just the receiver. With the case removed
Although I have now changed that to an orange rx one
Re: micro tug
« Reply #9 on: November 02, 2014, 06:54:59 pm »
so once the pot has been glued and it's circuit board is plugged in to the receiver it acts as a speed controller without the pot being turned....am I right??. also what voltage battery is coupled up to the motors and what voltage is placed up to the receiver???.............this sounds simpler than even I thought it could if that is the correct procedure.finally if the receiver is BEC would you only need one battery of 6 volts
cheers, Ian
Re: micro tug
« Reply #10 on: November 02, 2014, 07:28:13 pm »
I did something similar with my airfix landing craft  %),
Except I glued the motors partially through the hull and directly connected the kits props to the drive shafts, the pots have a cable reel attached to them as they protrude through the bulkhead in the loading bay and are partially adjustable (the glue did not stick too well). I did this so the model looks like the crew have something to reel ropes to, the battery is hidden under what looks like crates.
Still works even after being out of water for a while.
love it though, wish I could get any of my other projects on the go.
ian-mccaffrey
Re: micro tug
« Reply #11 on: November 02, 2014, 07:51:28 pm »
the receiver battery is 4.8v 1000mah ... and the battery at the front by the motors is just placed there to keep the motors in place whilst the glue sets for the motors lol
 and yes once plugged in to the receiver the servo bits act as a speed controller
Re: micro tug
« Reply #12 on: November 03, 2014, 09:45:25 am »
That is one very neat installation.
The servo boards give very good proportional control, albeit with a very small deadband.  With old type transmitters this could be put to good use by ignoring the stick, and using the trim slider as an engine room telegraph.  If you need that power but want a more conventional response, Actions Pico ESCs do the job, and are about the same size and weight.
What are the couplers?  I have mostly settled on the flint springs from disposable lighters as being highly available, and, with their tapered ends, a good fit on a range of shafts and especially good on the very short bit of shaft you get on a servo motor.
Tug Fanatic
Re: micro tug
« Reply #13 on: November 03, 2014, 11:56:42 am »
Looks great  :-))
What props will a standard servo motor drive?
Re: micro tug
« Reply #14 on: November 03, 2014, 12:09:56 pm »
cheers Ian......I can get on with my Frogg Oakley build now......cheers. neil.
Re: micro tug
« Reply #15 on: November 03, 2014, 12:11:38 pm »
and cheers for that info too, Malcolm.....gives me hope lol.
ian-mccaffrey
Re: micro tug
« Reply #16 on: November 03, 2014, 02:48:59 pm »
I might be interested in the pico speed controllers. I didn't realise they was that small
And the shafts are 2mm from marks model bits
And the couplings are from mark too
Not sure about what size props they will spin. But if personally say 20 mm is the max
hama
Re: micro tug
« Reply #17 on: November 03, 2014, 05:53:21 pm »
Please some "on the water shots" and perhaps a video??
Nice build, would never have thought of it!
Hama
Page created in 0.187 seconds with 17 queries.
