Author Topic: band saw  (Read 6099 times)
colin-stevens
band saw
« on: July 17, 2007, 09:09:57 pm »
thinking of bying a band saw. dont want a massive thing. at the largest i wil use it on 50mm insulation. but mostly for cutting out frames. also dont want to pay a fortune. any one got ant ideas. did a search and am baffled by the variety. so any recomendations wold be cool.
ta
colin
grumpy old XXX
John W E
  • I see no ships !!
Re: band saw
« Reply #1 on: July 17, 2007, 09:11:40 pm »
Hi Colin, what budget you looking at?
Knowledge begins with respect
sinjon
  • Sinjon
  • Model Bioat Mayhem Forum is the Best!
Re: band saw
« Reply #2 on: July 17, 2007, 09:23:44 pm »
Get an Axminster catalogue, big down to tiny, and economic too.
I recently got a bandsaw, a bench pillar drill, and a small wood turning lathe, didn't break the bank.
gingyer
Re: band saw
« Reply #3 on: July 17, 2007, 09:24:52 pm »
hi there,
I bought a scroll saw
it has so far cut
1/4 ply + 3" foam
with no problems I bought it from
B+Q for about £100 (I am sure it was less)
it is OK in size can be easily put a way when not in use
might be an other option than a band saw
Bryan Young
Re: band saw
« Reply #4 on: July 17, 2007, 10:28:38 pm »
The Rexon 3 wheeler is a good one, and replacement blades are easy to find.
Notes from a simple seaman
colin-stevens
Re: band saw
« Reply #5 on: July 18, 2007, 01:39:36 pm »
just hada gander at the Axminster site. not a bad price(£120)for the usage, may resort to jig saw and lots of filing.
going to see if i can track down a second hand one. not flea bay.
colin
grumpy old XXX
portside II
  • tugs at rest
Re: band saw
« Reply #6 on: July 18, 2007, 01:56:21 pm »
Dont forget trusty old B&Q
http://www.diy.com/diy/jsp/bq/nav/nav.jsp?isSearch=true&fh_search=band+saw&selected=products&x=24&y=6
£89.98  not a bad one i think it's the latest model .
or you could go for the screwfix one the same as mine and its delivered to your door in 2 days.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=56797&ts=63263
daz
colin-stevens
Re: band saw
« Reply #7 on: July 18, 2007, 04:32:56 pm »
thanks Daz. did a search of B&Q myself, nowt. then like magic, there you are with the link. what a gent
Ta one and all.
grumpy old XXX
mrsgoggins
Re: band saw
« Reply #8 on: July 18, 2007, 08:31:55 pm »
Have a look in Aldi - you might get a present surprise (and some beer with your change).
Chasing perfection but not running fast enough!
slewis
Re: band saw
« Reply #9 on: July 18, 2007, 09:20:57 pm »
I also go with B&Qs' own brand band saw , I have one myself and its ideal for hobby use . The only gripe I hav/had with it was the cutting guide . When locked into place it sits a good 1.5mm above the table so thin sheets slide under it  >:(
I fixed a thin sheet of fibreglass sheet to it so it now runs down to the table with no gaps underneath . You just need to remember to measure the cutting distance instead of using the built in measure .
Good piece of kit though  ;)
Shane
grasshopper
    • A1 Hobbies Ltd.
Re: band saw
« Reply #10 on: July 18, 2007, 09:48:08 pm »
I quite like Machine Mart, reasonable prices, good delivery and stores in major towns.  looking for a little bandsaw?
http://www.machinemart.co.uk/shop/product/details/cbs190-71-2-bandsaw
bigford
Re: band saw
« Reply #11 on: July 19, 2007, 02:46:39 am »
this is the one i'm waiting for the homedepot to get back in stock
a band saw will not give you the flexibilty you need for detail cutting
hastings246
Re: band saw
« Reply #12 on: July 19, 2007, 05:01:54 am »
Hey bigford,
Did you try Sears. I have noticed in California they are cheaper than homedepot.
Best Regards,
Sean
colin-stevens
Re: band saw
« Reply #13 on: July 19, 2007, 03:03:18 pm »
cheers guys, spoilt for chioce. fall to the one i can get the easiest
colin
grumpy old XXX
HS93 (RIP)
  • I cannot spell , tough
Re: band saw
« Reply #14 on: July 19, 2007, 03:27:09 pm »
thinking of bying a band saw. dont want a massive thing. at the largest i wil use it on 50mm insulation. but mostly for cutting out frames. ta
colin
If you are going to use it to cut out frames then get a fret saw, because you cannot cut the centers out of frames on a band saw, also try for one that has a quick blade release because some that you have to turn a nob to tension can be a bit slow if you have a lot of internal cuts.  If you do go for a bandsaw go for one that has ballrace guides and not just blocks as you will find it more accurate in the long run although some can be upgraded.
Peter
Page created in 0.172 seconds with 18 queries.
