Hi I think Marine qualiy ply is best quality with a 'Thames' version (?) a bit less so.
Do you have any marine stockists your way?
I bought some a few years ago from a marine source, very good.
Model Aircraft suppiliers such as Balsa cabin have supplied me in the past, sometimes length is a problem.
I am currently building model boats from my hoarded wood as when I kick the bucket it will probably be thrown away! Some of that wood came from deceased club members left overs.
You can always order a 8' x 4' sheet of ply via your wood yard, depends how much use you can make of the stuff, good time to share a cost with another modeller. If you can share get them to cut it for you otherwise not easy to get home.
Main thing I have learned is do not use cheap wood.
regards Roy
