Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: Tenby lifeboat  (Read 86866 times)
SailorGreg
Re: Tenby lifeboat
« Reply #25 on: February 23, 2015, 08:15:36 am »
Lovely!!   :-)) :-)) :-))
Re: Tenby lifeboat
« Reply #26 on: February 23, 2015, 10:29:47 am »
What a beautiful piece of work.
Well done Sir.     :-))
alan44
Re: Tenby lifeboat
« Reply #27 on: February 26, 2015, 06:45:46 pm »
Haven't done much this week just finished the life rafts.
Alan  :-))
craggle
  • Boaty McBoatface
Re: Tenby lifeboat
« Reply #28 on: February 26, 2015, 07:15:51 pm »
Fantastic build Alan, looks great.
I'm hoping to order the Speedline 1/12th Severn sometime this side of the summer, Seeing these pictures makes me want to order it sooner! :-)
Craig.
Model Slipway Envoy tug built.
Huge Lifeboat under construction.
Robin smith
Re: Tenby lifeboat
« Reply #29 on: February 26, 2015, 09:52:40 pm »
Make sure if you do order the Severn you get sufficient dummy 14BA bolt heads with the kit to complete.
mikew
Re: Tenby lifeboat
« Reply #30 on: March 02, 2015, 02:16:30 pm »
Alan I've been admiring the excellent paint work, what are you using and what method if you don't mind me asking??
49perkasa
Re: Tenby lifeboat
« Reply #31 on: March 02, 2015, 02:46:09 pm »
Amazing job,really impressive.
You can dance if you want to
alan44
Re: Tenby lifeboat
« Reply #32 on: March 02, 2015, 08:35:49 pm »
Hi mike.
I have used halfords spray paints for most things and humbrol enamels for small detail areas. I aim to have the prime coats as good as I can manage and then apply the colour coats lightly. The hull for example was 3 primer coats making good any defects until I was happy with the finish. Next stage was mask off above the water line. The White was built up with 5 light coats. I removed the masking tape after 8 or so hours then left it for a week to harden. You end up with a raised area where the tape sat this I carefully blended out. Re mask below water line and then 5 coats of blue. De mask and after a week I wet and dried the whole hull and gloss laquerd (3 coats) Dust is the real enemy of a good finish so I always use tack cloths
Hope this helps Alan  :-))
alan44
Re: Tenby lifeboat
« Reply #33 on: March 02, 2015, 08:43:50 pm »
Forgot to say I always apply my lettering then laquer over. This helps blend them in I think.
Alan  :-))
mikew
Re: Tenby lifeboat
« Reply #34 on: March 03, 2015, 09:51:16 am »
Hi Alan
Thanks for sharing that, is it the Halfords lacquer that you use? A few more weeks and I should be ready for the hull.
sailorboy61
Re: Tenby lifeboat
« Reply #35 on: March 03, 2015, 11:00:46 am »
Cracking piece of work! You must be justifiably proud.
alan44
Re: Tenby lifeboat
« Reply #36 on: March 03, 2015, 05:31:46 pm »
Hi Mike
I have used Halfords laquer. I learnt a very hard lesson where I mixed brands. I ended up with a crazy paving finish!!! It took about 3 months to develop and a lot of work to put right  >>:-(
Hope that helps.
Alan  :-))
mikew
Re: Tenby lifeboat
« Reply #37 on: March 04, 2015, 08:32:40 am »
Hi Alan
It certainly does help.
Many Thanks
mikew
Re: Tenby lifeboat
« Reply #38 on: March 06, 2015, 05:03:20 pm »
Hi Alan
Off to Halfords in the morning spend a wedge  {:-{
I keep looking at your photos and cant make out whether its gloss on the deck (grey) or undercoat sprayed with lacquer ??
alan44
Re: Tenby lifeboat
« Reply #39 on: March 06, 2015, 06:48:48 pm »
Hi mike.
You are almost right about my deck!!  Here are a few pics.   I used Rustolium stone effect finish for a grip effect (mask where required) slightly flat then 2 Halfords primer followed by 3 halfords satin lacquer . No sanding between coats you lose the grippy effect.  :-))  The deck colour varies Tenby's is quite light and prime was the best match I found.
Regards Alan.
mikew
Re: Tenby lifeboat
« Reply #40 on: March 06, 2015, 07:02:15 pm »
GAZOU
Re: Tenby lifeboat
« Reply #41 on: March 06, 2015, 07:13:26 pm »
Another extraterrestrial, but which man he is to make it
Atlantic Mouldings
Re: Tenby lifeboat
« Reply #42 on: March 06, 2015, 08:28:02 pm »
Superb , love the finish to the deck. :-))
Re: Tenby lifeboat
« Reply #43 on: March 06, 2015, 08:28:55 pm »
 :-)...I think our dear friend GAZOU was trying to say...........
Un autre extraterrestre, mais quel homme il est pour le rendre :-))
:o makes a lot more sense in it's natural tongue........  {-) Derek
Re: Tenby lifeboat
« Reply #44 on: March 07, 2015, 10:52:01 am »
Merci'    Derek
GAZOU
Re: Tenby lifeboat
« Reply #45 on: March 07, 2015, 03:09:02 pm »
Merci DERECK    %) {-)
Mark T
Re: Tenby lifeboat
« Reply #46 on: March 07, 2015, 03:55:16 pm »
That is an absolutely beautiful boat  :-))
alan44
Re: Tenby lifeboat
« Reply #47 on: March 08, 2015, 08:53:14 pm »
I have been struggling with the rear emergency escape hatch today. In the speedline kit you have an etched stainless hinge plate and a base plate. I decided to make a styrene secondary plate to match the full size. Small brass pins for the screw details. A bit of brass tube for the hinge.
Alan  :-))
alan44
Re: Tenby lifeboat
« Reply #48 on: March 10, 2015, 07:07:25 am »
I have now made and added the six deck lights and added some detail parts. Just wipers and capstans to finish.
Alan  :-))
Re: Tenby lifeboat
« Reply #49 on: March 10, 2015, 07:21:28 am »
Alan....I am not sure how to say this  :embarrassed: ....but I think you may need to get one of those 500 ml hand held water pump packs ....fill it with sea water diluted down to the scale ratio of the model......& gently spray over the vessel.......
 ;) ...as GAZOU said........ Un autre extraterrestre, mais quel homme il est pour le rendre :-))
Pages: 1 [2] 3 4 5 6 7   Go Up
Page created in 0.565 seconds with 18 queries.
