Author Topic: 120a Speedcontrol  (Read 3173 times)
AndreZS1AZ
120a Speedcontrol
« on: January 13, 2015, 01:58:48 pm »
I need some help.  I hooked up my Turnigy 120a marine esc to a 3660SL 3180kv motor.  The esc and wires got hot after +- 40 seconds and only drawing 40 amps.  Any ideas?  This is for a 1/10th hydroplane.
It is not the fall that kills you, it's the sudden stop
TomHugill
Re: 120a Speedcontrol
« Reply #1 on: January 13, 2015, 11:12:49 pm »
Hot or warm?
« Reply #2 on: January 14, 2015, 01:43:02 am »
Andre.......you need to confirm a few more points :o
40 amps @ what voltage?
prop style...diameter, number of blades & pitch?
loaded or unloaded?
as Tom asks....how hot?
AndreZS1AZ
« Reply #3 on: January 14, 2015, 12:53:16 pm »
That is the motor.  The esc was hot, not warm.  Using 11.2v lipo pack.   I come from an nitro rc plane background and am possibly doing EVERYTHING wrong.  I hooked up a 12" wooden plane prop and bench ran it to check currant draw.  I guess that this is not the correct way.  All help will be appreciated once you have stopped  {-)
Calimero
    • Calimero's RC shed
« Reply #4 on: January 14, 2015, 01:03:21 pm »
You had water flowing through the ESC and motor, right ?
AndreZS1AZ
« Reply #5 on: January 14, 2015, 01:46:29 pm »
Nope, no water.  I did not think that it would matter for the short test that I did.  Motor was cool.  As I said, need help and I am willing to learn.  lots of questions still to asked if you guys don't mind.  Give me nitro and I'm happy but with brushless I am feeling my way with help.  The hydroplane is still under construction as I am waiting for parts that a friend from the US has posted.
Calimero
« Reply #6 on: January 14, 2015, 01:51:49 pm »
With 40 amps going through I would run water through the ESC. Water-cooled ESC really need the water. They're not like Car ESCs with big heat-sinks (and sometimes fans).
Getting hot under 40 amps with no water cooling doesn't sound unusual to me.
AndreZS1AZ
« Reply #7 on: January 14, 2015, 04:51:22 pm »
Thanks for the replies.  Now, is this too much motor for the esc?  I was thinking that the esc would be able to handle 40 amps without water cooling.  OK, I think that I see where you guys are coming from.  The ideal thing would be for me to build a test jig with, say a 45mm prop, add some forced water cooling and try again.  Would the prop then be loaded if this setup is static?
Calimero
« Reply #8 on: January 14, 2015, 05:49:44 pm »
Water-cooled ESC usually s*uck without the water cooling. You could try again with the airplane prop but with a bottle of water (or a small water pump) feeding cooling water and see how that turns out.
Static testing of a fast-electric is not so easy. To get a somewhat realistic figure you'd have to keep the hull level with the prop half-submerged only. Good luck on a small water tank ...
AndreZS1AZ
« Reply #9 on: January 14, 2015, 06:13:34 pm »
Thanks Calimero, Tom and Derek.  I have now come to the conclusion that you do not run a water cooled esc without the water :embarrassed:  No problems with the water tank.  I do not have my strut or flex shaft at the moment but I can make a test jig using a straight shaft and use a friends swimming pool.  I will use a gravity feed for the water cooling for test purposes.  As I said , I am new to fast electric and need help.  The hydroplane will be 87cm long and the weight is unknown at the moment.  All ideas are welcome.
Page created in 0.013 seconds with 18 queries.
