Author Topic: Receiver question?  (Read 7365 times)
Paul R
Receiver question?
« on: July 22, 2007, 09:51:49 am »
Can a 4 channel hitec receiver be used in conjunction with a hitec 6 channel transmitter, or does the receiver also need to be 6 channel as well?
Paul R
HS93 (RIP)
  • I cannot spell , tough
Re: Receiver question?
« Reply #1 on: July 22, 2007, 10:09:55 am »
Yes as long as they are the same type   IE ...Dual Conversion with Dual Conversion   .......... single  Conversion with   single  Conversion
Peter
Youngat65
« Reply #2 on: July 22, 2007, 11:08:29 am »
You shouldn't have any problems I do it all the time
                                           BobB
portside II
  • tugs at rest
« Reply #3 on: July 22, 2007, 04:09:29 pm »
BobB  what happens if you use a 6 chanel reciever with a 4 chanel transmitter  8)
daz
« Reply #4 on: July 22, 2007, 05:51:49 pm »
No propbs at all simple reason really if u got a 4 channel set u wont be able to use channel 5&6 will u the other 4 will work stavros
Youngat65
« Reply #5 on: July 22, 2007, 05:54:24 pm »
Good question Daz can't answer that right now will try it and let you know ...........or send you the bill for a new recevier  ::) ::)
        BobB
Paul R
« Reply #6 on: July 22, 2007, 07:45:53 pm »
OK, Thanks guys for those replies , I thought that might be the case, just thought i'd better check first!
Paul R
ministeve
  • washing the decks!!!
« Reply #7 on: July 22, 2007, 08:09:57 pm »
talking about trannys can a 35meg tx be converted to 40meg?
FullLeatherJacket
« Reply #8 on: July 22, 2007, 08:47:22 pm »
Ministeve
I know this one............No, unless it has one of those removeable RF module things in the back. Best to get a new set.
FLJ
ministeve
« Reply #9 on: July 22, 2007, 10:47:05 pm »
will do i have seen lots of 35meg sets on ebay going cheep thought i might get a bargain alternatively can we use 35meg at pondside if not why whats so special about it
kendalboatsman
« Reply #10 on: July 22, 2007, 10:52:46 pm »
Hi Ministeve,
The powers that regulate frequencies in the UK  allocated 35Mhz exclusively for model aircraft for safety reasons. Cars and boats can share 27 and 40Mhz but 35Mhz was set aside to stop surface model users from making planes fall out of the sky onto joe public.
At least that is the reason I was always bought up on.
Clive :)
« Reply #11 on: July 22, 2007, 10:53:28 pm »
35 meg is reserved for aeromodellers (legal requirement) . If you use it for a boat or car somebody will come along and shoot you!
justboatonic
« Reply #12 on: July 22, 2007, 11:06:22 pm »
IIRC you can still fly on 27Mhz However it is not recommended especially as 35Mhz is solely for RC aircraft (planes, gliders and helis).
When 35Mhz, our local Beatties store (the group closed a few years back) were selling 35Mhz gear with RC Cars! We had a job to get them to stop but eventually agreed(!) to supply only the then 27Mhz band equipment.
ministeve
« Reply #13 on: July 22, 2007, 11:12:04 pm »
oh well another idea out the window that Joe public. always throwing spanner in the works ;D
« Reply #14 on: July 22, 2007, 11:18:40 pm »
Sounds bureaucratic but people have been killed and injured by out of control model planes so there is a good reason for it.
« Reply #15 on: July 23, 2007, 12:23:13 pm »
Actual conversion is not particularly difficult or in itself expensive, but getting the appropriate test gear and expertise to ensure a working and legal result is.
The ready built sets come with a type approval which certifies that they are legal for use, and, if unmodified, provide an indemnity path just in case.  Using a modified or home made/modified transmitter must always involve some crossed fingers.
portside II
  • tugs at rest
« Reply #16 on: July 23, 2007, 06:01:58 pm »
ok so 35mhz is reserved for the aircraft band .
right then what about power from these transmitters ,i have a hitec eclipse7 that was originally on 35mhz  so when i converted to marine i bought the 40mhz module and there we go ,but the thing is when flying aircraft it is done at a range far greater than we would controling a boat so does this mean my tx has a greater output than a normal 40mhz unit??
daz
« Reply #17 on: July 23, 2007, 09:22:04 pm »
If is is a type-approved module, this includes the power output.  I did have a link to the appropriate site specifying power output limits once, but it seems to have gone walkabout.  The thing is, if you use a propietary transmitter, it will be legal, not only that, but it will work without any ill effects to anybody else around.
portside II
  • tugs at rest
« Reply #18 on: July 23, 2007, 10:37:49 pm »
so does that mean the module controls the output power of the transmitter.
daz
HS93 (RIP)
« Reply #19 on: July 23, 2007, 10:42:40 pm »
 Yes it does , tx on 35mhz and 40 mhz are allowed top use the same power, equivalent radio gear should have the same output, some of the budget stuff can be a bit lower.
Peter
