Author Topic: Brushless set up for ARUN 52  (Read 8419 times)
maggie m
« on: January 24, 2015, 10:19:58 pm »
HELP, looking for advice on Brushless setup for an ARUN 52 lifeboat, ie Motors, and speed controlers, wish to use independent control on each motor, Thanks
Time Bandit
Re: Brushless set up for ARUN 52
« Reply #1 on: January 24, 2015, 10:26:17 pm »
Scale, size, weight?
Props (diameter, type, pitch?)
Btw, independent control is a must with brushless motors.
regards
Tobias
maggie m
« Reply #2 on: January 24, 2015, 10:42:27 pm »
HI Model, is made by Models by Design, at 1.12 scale, do not know completed weight, wish to use two 12v batteries SLA ,thanks
Time Bandit
« Reply #3 on: January 25, 2015, 09:17:05 am »
Okay that makes it easier  :}
So 1.33 m long and probably weight´s something around 15kg.
If we guess that you will use 55mm Raboesch brass props you should choose a motor which turns around 4000-4500 rpm under load.
Since it´s brushless you´ll need 5000 rpm without load or 416kv.
UK warehouse  shows these:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18169
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=19616
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=19028
I´d use the first one with each a Roxxy 960 ESC.
Motor is big enough not to die over thermal problems and no too expensive.
regards
Tobias
TugCowboy
« Reply #4 on: January 25, 2015, 09:29:38 am »
Good advice above, I use 2 x G46's with a similar size tug, plenty of power. (3rd link above) but any of those 3 are about the right power for what you need.
They don't really need too much in the way of cooling either as long as there is some space in the hull for air to move about. If not then a simple water cooling jacket could be used but not absolutely necessary unless you are doing sustained long runs in towing competitions etc.
The Hobby king ESC's are fine too if you want to save a bit of cash on those.
maggie m
« Reply #5 on: January 25, 2015, 10:09:04 am »
Hi Guys thank you for all your help, could you tell me what speed conrtolers from hobby king would be the best to use, again many thanks
Bill D203
  • not long now!!
« Reply #6 on: January 25, 2015, 12:17:12 pm »
I did try to reply yesterday to this post but Mayhem site was having issues.
Anyway heres what I did with my Arun.
Honda !
maggie m
« Reply #7 on: January 25, 2015, 02:11:29 pm »
Hi thank you, thought about a 2 stroke, problem is there is no IC models permitted, was going to use a brushless setup running on 24v,
Bill D203
  • not long now!!
« Reply #8 on: January 25, 2015, 02:24:15 pm »
Yes that is a pity you can't run IC boats where we want to. By the way the engine is 4 stroke so is Oil free ( it has an oil sump so none added to the fuel )and very little noise to upset anyone. I have run my Arun at Mayhem weekends and the biggest moan i get is about the wash of the boat even at very low speeds. Still my 1/16th Tamar make a wash that upsets some  {:-{  i think it is just lifeboats!
maggie m
« Reply #9 on: January 25, 2015, 02:37:15 pm »
Hi Bill, what Honda engine is it that you  are using ?, problem  is Loch  is used for Fishing ,thanks
Bill D203
  • not long now!!
« Reply #10 on: January 25, 2015, 04:16:26 pm »
I can't remember its numbers but its modern number is GX22 . 22 cc However I had to have made for me a gearbox to drive the two props around counter rotation. The box was just about £100 worth of parts to make it.
The engine cost around £50.00 on ebay as a none runner. I soon had it purring over with a few broken parts replaced. I have to say Ive got some work to do to improve the exhaust manifold when it warms up and I can work on it outside.
Best stick with the brushless set up as i did with my Tamar.
maggie m
« Reply #11 on: January 25, 2015, 05:00:29 pm »
Hi Bill what scale is your Tamar ?, can I ask what brushless set up,you use, ie batteries etc thanks George
Bill D203
  • not long now!!
« Reply #12 on: January 25, 2015, 05:34:15 pm »
yes my Tamar is a Model slipways 1/16th scale
I use two 11.1 volt 5000mah Lipos on for each motor. the motors are turnigy 1250 kv  3542 motors. Hobbyking 50amp water cooled ESC (however i don't use the cooling as they have never got hot so far)
This powers up the boat well over scale speed so i never open the throttle to much.
Bill D203
  • not long now!!
« Reply #13 on: January 25, 2015, 05:41:22 pm »
Even my Y boat has a motor and RC . I loved making my Arun.
maggie m
« Reply #14 on: January 25, 2015, 05:55:57 pm »
Hi Bill, thank you for info, I also have an untouched Model Slipway Trent, and a Metcalf 47ft Watson also unstarted, the possibility that they shall end up Brushless aswell, Best Regards George
destroyer42
« Reply #15 on: January 25, 2015, 06:28:10 pm »
Hi Maggie m,
I have an Arun lifeboat, it has 2 x 4blade 75mm propshop props, 6 mm shafts, 2 x 50amp tuborix brushless ESC's, 2 x Emax BL 4030 850kv.
Runs on 12v for shows and 24v if I really want shift and it's fast.
Destroyer42
maggie m
« Reply #16 on: January 25, 2015, 07:39:27 pm »
Hi looking at previous posts it was recommended that I use 55mm props , would it be okay to use 65mm 4 blade props, thanks george
Time Bandit
« Reply #17 on: January 25, 2015, 09:10:54 pm »
The motors in my recommendation will also run with 65mm props.
The 55mm was just a rough guess without knowing the actual diameter.
regards
Tobias
maggie m
« Reply #18 on: January 25, 2015, 09:34:04 pm »
Hi many thanks for information, regards George
