On my Fairmount Alpine railings and there's a lot ,the materials I used was bakers fluid,core solder variable temp soldering iron . The stanchions are about .05 mm think , top rail .75 mm and the bottom 2 rails are .50 mm . The brass was pushed through the holes and a very small drop of Bakers fluid put on the joint tin the iron and wipe of excess solder ,when the tip just touched the joint the solder flashes into the joint there was no cleanup . I tried silver solder but because the material was so thin it just destroyed.
David
