Author Topic: 1 mm plywood  (Read 4466 times)
regiment
1 mm plywood
« on: February 10, 2015, 02:41:05 pm »
HELP  HELP  where do I buy 1mm plywood from I need a bit 24x24 inches to start my yacht got the rest of the stuff but no wood the sails and mast  are from a kite I found on the beach the rudder will be made from a fin from a surf board the tube is made from an old metal pen and a piece of coat hanger for the rudder shaft if  anybody interested in a sheet off white softish  plastic like plastruct got a picture on but can be painted over size 23 x 16 inch post only
irons01
  • 1/72 HMS Hambledon built and sailing....
    • Facebook build page
Re: 1 mm plywood
« Reply #1 on: February 10, 2015, 03:42:44 pm »
Tried the Model Dockyard? http://www.model-dockyard.com/acatalog/Playwood.html  I got mine from there, great service!
Re: 1 mm plywood
« Reply #2 on: February 10, 2015, 04:18:39 pm »
Why are you using such thin plywood Gordon?
Is it for skinning the hull?
The ply mentioned by Irons is only 12 ins wide.
1 mm will give you an easily punctured hull unless
you are glass clothing it.
Arrow5
Re: 1 mm plywood
« Reply #3 on: February 10, 2015, 04:32:37 pm »
Aeromodelling shop is best bet , but as Ned says maybe 1/32nd might be better and cheaper.  Ask for "Miraply" for the 1/64th but expect shock at price.
..well can you land on this?
barriew
Re: 1 mm plywood
« Reply #4 on: February 10, 2015, 05:07:44 pm »
Gordon
Both SLEC and The Balsa Cabin sell all thicknesses of ply in various sizes - including 24" x 24". Its expensive as has been said.
Barrie
Re: 1 mm plywood
« Reply #5 on: February 10, 2015, 05:52:39 pm »
Steve model boat bits mobile marines and deans marine all sell plywood
regiment
Re: 1 mm plywood
« Reply #6 on: February 10, 2015, 07:02:58 pm »
talking to this person (mr know all) at the lake on sunday I mentioned I was going to try and build my first plank on frame yacht he said 1mm ply will be ok.. size will be 22 inch long just right to carry o well back to the drawing board and the bank manager thanks to all for help
Re: 1 mm plywood
« Reply #7 on: February 10, 2015, 08:09:49 pm »
Gordon....Ned is correct......unless the framing near perfect in form....even light sanding will render the planking paper thin  >>:-( .... Derek
regiment
Re: 1 mm plywood
« Reply #8 on: February 11, 2015, 10:06:28 am »
plywood what thickness is best   gordon
Re: 1 mm plywood
« Reply #9 on: February 11, 2015, 10:56:49 am »
Evening Gordon....even with the planned hull at 22", I would avoid any form or thickness of plywood for hull planking
By the nature of its construction....eg., 3 ply...we have both outer layers with the grain in the horizontal plane & the inner layer with the grain in the vertical plane...which is great for mechanical strength but it does not want to bend in the 3rd plane ...and is a hard material
Cedar planking can be bent & twisted in two planes, steamed if needed, is a much softer material which can easily be sanded
This sandability has the advantage that it is easy to sand a chamfer on adjoining plank edges to ensure a good profile fit
So again even for a 22" hull, I would consider 1/8" thickness x 1/4' width cedar planking worthy of consideration for a good start :-)) .... Derek
regiment
Re: 1 mm plywood
« Reply #10 on: February 11, 2015, 11:09:18 am »
morning afternoon or evening it is 11 am here just the answers I needed but what is 1/8th in mm   gordon
Re: 1 mm plywood
« Reply #11 on: February 11, 2015, 11:14:28 am »
3.175 mm Gordon.
roycv
Re: 1 mm plywood
« Reply #12 on: February 11, 2015, 11:20:30 am »
Hi regiment do you not have any boat builders around your area?  I am thinking off-cuts.
regards Roy
Page created in 0.029 seconds with 17 queries.
