Pages: [1] 2 3   Go Down
Author Topic: DELTA IV Russian submarine 1/96  (Read 30459 times)
bassplayer1
« on: March 16, 2015, 10:17:44 pm »
Hallo everyone
Here is a project I've been working on the last couple of years! Length 168cm, Beam 15cm
I'll be posting photos of the whole works right from the start so here it goes!
bassplayer1
Re: DELTA IV Russian submarine 1/96
« Reply #1 on: March 17, 2015, 10:32:40 pm »
Good evening
Some more photos of adding some detail to the hull and making the masters of the dive planes and ruders
bassplayer1
« Reply #2 on: March 18, 2015, 08:53:54 pm »
Some more photos of the work on dive planes and ruder
unbuiltnautilus
« Reply #3 on: March 19, 2015, 09:18:52 am »
Looking good already. I am looking forward to some good ideas worthy of pinching for use on upcoming models of my own :-))
Arrow5
« Reply #4 on: March 19, 2015, 09:48:23 am »
Is this made from "blue foam" ?   What skin ? Epoxy resin ? With glass or without?   Just being nosey :embarrassed:
..well can you land on this?
U-33
  • K-157 Vepr. Akula-11
« Reply #5 on: March 19, 2015, 10:42:46 am »
Superb work...wish my boats came out like that.   <:(
profesorul
« Reply #6 on: March 19, 2015, 10:47:27 am »
What materials You use to finish so smooth the surface before paint ?.
I can see the plastic tubes but there all upside down .
MARIUS
Arrow5
« Reply #7 on: March 19, 2015, 12:18:50 pm »
Prof,  I think they are tubes of hardener for two part car bodywork filler, the paste part is in the blue tin on the left.  However that is part of my question too, the usual fillers (polyester) would dissolve the blue foam unless protected.  Bassplayer will put us right. :-))
pugwash
« Reply #8 on: March 19, 2015, 03:00:29 pm »
Yannis good to see you back again building submarines but how is the Kerkyra ferry getting on
Geoff
bassplayer1
« Reply #9 on: March 19, 2015, 03:54:08 pm »
Thank you very much for your kind words all of you! They are much appreciated!
bassplayer1
« Reply #10 on: March 19, 2015, 03:55:51 pm »
Yes, it's made of blue foam covered with 200gr glass cloth and epoxy
bassplayer1
« Reply #11 on: March 19, 2015, 04:01:48 pm »
This is absolutely right and as I mentioned above the foam is protected with glass cloth and epoxy. Prof, the final finish is sprayed on with two pack automotive filler.
bassplayer1
« Reply #12 on: March 19, 2015, 04:06:40 pm »
Geoff
Thank you Geoff .
Kerkyra ferry has to wait a bit. I had to finish this one as it is an order from a new french company that is going to market it quite soon!
profesorul
« Reply #13 on: March 19, 2015, 06:15:31 pm »
THANK YOU YANI .  :-))  ,
But I steel have a question :
- what putty / filler You use for smooth finished surface , before painting .
- do You know some soft putty / filler for brush applying ?.
MARIUS
P.S - Good Luck with the French Company !.
bassplayer1
« Reply #14 on: March 20, 2015, 11:29:55 pm »
Prof
as I mentioned above I use a sprayed on two pack automotive filler-primer.You can buy it from shops that sell paints and stuff for cars. The smooth finish is achieved by sanding it with a fine grade wet and dry sand paper. The brand I use is called BODY and I'm sure you can get it in Romania. Yes, you can do it with a brush but it will be more work in sanding!
bassplayer1
« Reply #15 on: March 20, 2015, 11:36:00 pm »
Starting the scribing busines
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #16 on: March 22, 2015, 12:42:04 pm »
Very nice. What tools are using for scribing and are using a template? The depth seem very consistent.
profesorul
« Reply #17 on: March 22, 2015, 04:58:44 pm »
Along with the answer for @ Mankster , PLEASE put some pictures with the tools used . My English is not very good  ok2    %%
MARIUS
bassplayer1
« Reply #18 on: March 22, 2015, 08:18:06 pm »
Here are the tools and tenplate I use. For more complicated shapes I make the templates out of cardboard or tape. For square panels I use the DYMO tape shown in the second photo, works a treat! There are many videos on You Tube showing the technique, just type "scribing"
bassplayer1
« Reply #19 on: March 22, 2015, 08:26:13 pm »
Some more photos of the scribing busines
gingyer
« Reply #20 on: March 22, 2015, 09:47:14 pm »
The submarine looks awesome  :-))
What's the other models in the back ground??
It looks like a Hercules and a type 214 submarine
bassplayer1
« Reply #21 on: March 23, 2015, 10:51:45 pm »
Yes, that's right, it is a C-130 and a 214 sub!
Thanks for your kind comment  :-)
bassplayer1
« Reply #22 on: March 23, 2015, 10:55:37 pm »
Some more general vews just before starting moulding
profesorul
« Reply #23 on: March 24, 2015, 07:56:23 am »
THANK YOU Kir YANI
MARIUS
bassplayer1
« Reply #24 on: March 25, 2015, 08:44:42 pm »
Thank you Prof  :-)
Pages: [1] 2 3   Go Up
