Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16   Go Down
Author Topic: SEABEX ONE scratch build  (Read 156340 times)
thething84
Re: SEABEX ONE scratch build
« Reply #75 on: May 07, 2015, 11:01:52 pm »
tagging along. awesome build. looking great and coming along nicely.
If it ain't broke! Fix it anyway!
GAZOU
« Reply #76 on: May 08, 2015, 09:07:15 am »
Tug-kenny
Hello
The net mosquito net is completed for the scale known SEABEX, I used it on my model of  supply " EDDA FONN ". 1/50 .
I can you  send by mail.
Thank you for following the subject of the SEAPOD on other forums
The SEAPOD works perfectly without transformation of the radio
« Reply #77 on: May 08, 2015, 09:50:02 am »
I think onion/apple/pears etc net scales at about 1 yard square holes at 1/72 so people could pass through, the Garlic mesh might scale about 1 foot at 1/72, tights might scale at a more realistic 4" at 1/72, or warship scale net might be a better bet
GAZOU
« Reply #78 on: May 08, 2015, 11:18:29 am »
I think that the packagings of apples pears onions and other vegetables are techniques of the previous century
Dimension an euro = dimension an pound
It is necessary to work with materials of today  .
vnkiwi
« Reply #79 on: May 08, 2015, 11:22:29 am »
But, fly screen has been around forever.
 :P
« Reply #80 on: May 08, 2015, 11:27:17 am »
I agree with you  Gazou.
The whole problem has been one of stretching material.  It looks still on-going but it's certainly a challenge. I am now worried about attaching said net to  'sticking out'  bars, at an angle all around the circumference of the flight deck.
 I will take some pictures of the materials I have along with a 1:75 model person, later,  when I finish my clerical work on here.   tehe
cheers
GAZOU
« Reply #81 on: May 08, 2015, 01:23:39 pm »
« Reply #82 on: May 08, 2015, 04:18:09 pm »
Brilliant, Gazou.  Thank you very much.
I have copied it to my drawings section and will use this design and way of doing things.
Here is the net just stretched and laid out on the poles.  (didn't know how to attach it, but I do now)  :-))
I have the little man looking at it from above.    {-)
« Reply #83 on: May 08, 2015, 04:23:12 pm »
I then cut out the rear deck with an access hole as I will need to work in there later.
« Reply #84 on: May 08, 2015, 04:53:04 pm »
Ken it'slooking good.
Tell the domestic manager that you want to go organic.
The onions come in Brown nets which look more authentic.
« Reply #85 on: May 08, 2015, 04:55:44 pm »
How long does the smell take to go.    {-)    {-)    {-)
« Reply #86 on: May 08, 2015, 04:58:01 pm »
Quicker than the white nets from the garlick  {-)
GAZOU
« Reply #87 on: May 08, 2015, 05:25:16 pm »
Look "at holes" of the red net, the small man is going to pass in the fault O0
« Reply #88 on: May 08, 2015, 07:42:25 pm »
I'll keep looking as these are not good.
« Reply #89 on: May 12, 2015, 10:40:08 am »
see see see, told you so  :P :P :P :P
Onion net red and BIG, Garlic net SMALL, he he he he, lol, a finer mesh is available as the JML (product placement not intended) fly screen mesh, and even smaller than the garlic mesh, KUDOS to vnkiwi
« Reply #90 on: May 12, 2015, 10:44:16 am »
Thank you for pointers.  yes, it is proving a problem. I do need a finer net so I'll be researching this further.
tattooed
« Reply #91 on: May 12, 2015, 07:12:50 pm »
hi ken
great build :-)) i've got some 2mm netting if it's any good to you , have you finished the fire engine yet?
is this to big for you ken?
Andy
if it looks right and your happy with it then it is right
« Reply #92 on: May 12, 2015, 09:16:14 pm »
It does look like  1mm  might be the maximum gap.  I am looking for a rigid material now because any net  (by virtue of it's design) will stretch.
I have jumped this part of the build and got on by starting the crane.  I did one before on the  Gry Matitha  that I've built and just loved working out the motors to bring it to life. Pictures will follow as I progress.
david48
« Reply #93 on: May 13, 2015, 09:31:33 am »
This may be of no use at all , at a railway show the other week and there was a guy selling photo etch mesh panels for  the Deltic Locos ,so envy photo etch shop would do any size . The only thing it might look a bit clinical as you would not get the natural sag of net .
David
« Reply #94 on: May 13, 2015, 09:33:25 am »
What a brill!  idea. I never thought of model railway stuff.  I'll look into it and see what's around.
Thanks for the heads up
John W E
  • I see no ships !!
« Reply #95 on: May 13, 2015, 10:31:53 am »
Hi Ken
have a look at plain white window net curtains  :-))
aye
john
Knowledge begins with respect
boman
« Reply #96 on: May 13, 2015, 10:46:22 am »
Screen door mesh. I have a heap here and it measures approx. 1.5mm square. And it was cheap by the meter from a hardware store.
Brian60
« Reply #97 on: May 13, 2015, 11:53:46 am »
I bought some 0.5mm stainless mesh for my build. Its fine for the treadplates that I needed to make up.
At 1/72nd scale  a 4inch hole works out to 1.4mm so using flyscreen mesh would be ok for that. But if you wanted rigidity, you can get the mesh in sizes up to 2mm. Mine came from ebay, a model engineer supplier. The only problem with using it is that you epoxy to bond it to other stuff like plastruct section. I framed mine with 1.1mm plastruct, it can be seen in post 95 .......
http://www.modelboatmayhem.co.uk/forum/index.php/topic,49047.95.html
« Reply #98 on: May 13, 2015, 08:38:16 pm »
That could be just the job Brian.  Thank you.  I shall look into it.
Maybe be able blend it with some curtains John.   :}
No pictures today as the crane has more lattice work than a Victorian boudoir. Hundreds of tiny sections keeping me very busy  !
Cheers all
« Reply #99 on: May 15, 2015, 10:09:51 am »
This section has taken some time.   %)   The crane.   O0
After cutting masses of little pieces and struts, here is the boom section nearly ready. I've used 2mm plastic card for a more rigid support.
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16   Go Up
Page created in 0.633 seconds with 18 queries.
