Pages: 1 [2] 3 4   Go Down
Author Topic: Airfix Royal Soveriegn  (Read 30140 times)
Re: Airfix Royal Soveriegn
« Reply #25 on: July 10, 2015, 09:03:41 pm »
That is about the same cost as the Victory built a century plus later!
kpnuts
« Reply #26 on: July 12, 2015, 03:25:45 pm »
Hi all I've decided to do something different with this and it involves this
It flickers just like a real candle and the other one is kaput so I developed a cunning plan so, off with the transom
can you guess where this is going
drilled out the windows
then removed the rest of the window
yes thats right I'm going to RC it, only joking, lighting up the state cabins.
« Reply #27 on: July 12, 2015, 08:42:13 pm »
It looked rude for a second until I recognised what it was! Are you going to illuminate the lantern as well? You can get flickering LEDS.
kpnuts
« Reply #28 on: July 12, 2015, 08:45:34 pm »
I think the lantern is beyond my level its tiny.
« Reply #29 on: July 12, 2015, 08:49:59 pm »
Fair do's.
steve pickstock
« Reply #30 on: July 14, 2015, 07:04:34 am »
You can get battery powered 'tea lights', same effect just in a much smaller battery powered package. They're normally 4 for £1 in a  B&M or similar kind of shop. Wargamers build them into cotton wool balls to make burning markers. A couple of them strategically placed within the hull would do the job.
kpnuts
« Reply #31 on: July 19, 2015, 07:50:17 pm »
Hi all a small update on this, The transom sticks out past the gallaries on the sides and I didnt like the way Airfix just moulded them flat so I've rounded the edges and reguilded them
also the grills on the prow are not moulded all the way through so I drilled all the holes out.
and I've hacked the candle apart and reconfigured it
« Reply #32 on: July 20, 2015, 09:10:26 pm »
That is a lot of electronics for a flash isn't it! She's coming on splendidly.
kpnuts
« Reply #33 on: July 22, 2015, 06:04:13 pm »
Hi all here is another update on her
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size][/color]
steve pickstock
« Reply #34 on: July 22, 2015, 08:25:08 pm »
How about some sort of diffuser inside the windows?
« Reply #35 on: July 22, 2015, 09:49:20 pm »
She looks very realistic with that subdued gold and black-blue.
Lovely with loads more still to entice us with!
kpnuts
« Reply #36 on: July 26, 2015, 05:09:37 pm »
Hi all here is another update on this lovely little kit, it really is a joy to build.
kpnuts
« Reply #37 on: July 27, 2015, 08:06:44 pm »
Hi all here is tonights update
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size][/color]
kpnuts
« Reply #38 on: July 29, 2015, 08:35:40 pm »
Hi all here is tonights update, I've tried to do the cannon anchors and the ammo boxes.[/size][/font][/color]
[/size]
[/color]
[/size]
[/color]
[/size]
[/color]
[/size]also tried an experiment with the vac formed sails[/color]
[/size]
[/color]
[/size]
[/color]
[/size]which looks most realistic[/color]
[/size]
[/color]
« Reply #39 on: August 02, 2015, 10:00:07 pm »
Lovely work Ken! I like the idea you have tried on the sails, it adds a good texture to add paint effects tpo doesn't it.
kpnuts
« Reply #40 on: August 09, 2015, 06:39:07 pm »
Hi all here is an update on this one. All the guns in place (still got to tie some down) all the closed gunports glued in.
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size]I've discovered that the slots in the grating for the bowsprit tie downs are not there so had to make them.[/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size][/color]
« Reply #41 on: August 09, 2015, 07:07:43 pm »
Looking very impressive - looking forward to seeing more of this one :-))
kpnuts
« Reply #42 on: August 11, 2015, 08:15:26 pm »
[/size]Hi all made a start on the water effects.[/color][/size][/font]
[/size][/size][/size]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
[/size][/color]
[/size]
[/color]
« Reply #43 on: August 11, 2015, 08:30:45 pm »
The animation of your water is excellent Ken. Are you going to add kapok/cotton wool to the wave crests to add spray?
kpnuts
« Reply #44 on: August 11, 2015, 08:34:19 pm »
I was going to give it a try also not sure whether  to add a bit of green to the bottoms of the waves, what do you think.
« Reply #45 on: August 11, 2015, 08:42:57 pm »
Why not, give it a go!
Nemo
« Reply #46 on: August 11, 2015, 09:22:00 pm »
These are handy when you want to simulate fire at sea without the danger of naked flame. On our club illuminated evening last year, my Billings Osberg Longship was adorned for a Viking Funeral with the 'body' laid out surrounded by these lights and some coloured tissue and looked very effective. No use in broad daylight though!
kpnuts
« Reply #47 on: August 14, 2015, 09:10:26 pm »
kpnuts
« Reply #48 on: August 19, 2015, 07:58:02 pm »
Hi all well I know nothing about rigging so I'm going to do a cross between the Airfix instructions and ones I've downloaded off the internet (I could not possibly do them the way they are supposed to be, I don't have a clue as to where to start) I dont even know what the different lines are called.
also I bought this to do the ratlines with
but This came with the Airfix Wasa kit
which would be the easiest to use.
« Reply #49 on: August 19, 2015, 10:22:17 pm »
I know there was Standing Rigging such as the Shrouds (They hold the masts up and have the ratlines tied to them) and then there is running rigging, which include all of the sheets etc used to raise, lower and adjust the sails etc.
The former can be depicted black-brown as they suffered the elements and were soaked in pitch, while the running rigging was a more natural colour-linen like as they were tugged about and often stowed away when not used. As to names etc, I am as fresh to it as you and it can change from era to era as sail and rigging evolved.
There are some good videos on Youtube showing the tying of ratlines and other rope types, also one of last year's Model Boats had a good article on folding sails, it is more involved than I imagined!
Pages: 1 [2] 3 4   Go Up
Page created in 0.034 seconds with 18 queries.
