Author Topic: Strut Props: What do people use?  (Read 3550 times)
NobbySideways
  • Fairey Huntsman 31 Build in progress
« on: June 03, 2015, 01:52:52 pm »
I believe I should be supporting the end of the prop tube on my Hunstman with a prop strut, but although they seem readily available for fast electric I can't seem to find any for normal electric boats.
Any advice please? Or do people just let the tube protrude from the underside of the hull without support? %%
Thanks in advance for any help you can render.
david48
Re: Strut Props: What do people use?
« Reply #1 on: June 03, 2015, 01:59:07 pm »
I do not know how much prop tube you have , I think what you should do a search for "P" brackets or "A" brackets ,if I remember that what thy call them . You could make your own ,sleeve the tube be it brass or plastic fix a leg and attach to hull.
Hope this is some help
NobbySideways
« Reply #2 on: June 03, 2015, 02:00:54 pm »
Excellent advice, thanks. At the moment I don't have anything in place, I am awaiting the motor before I go ordering the prop tube so I can get it as low and forward as possible.
I think terminology is my biggest problem with this Hobby. I remember the first day I read the instructions for my boat and the first thing I had to do was look up "Transom"....  :embarrassed:
« Reply #3 on: June 03, 2015, 02:09:16 pm »
Go and peruse Steve Tranter Model Boat bits and he does various Prop supports and shafts
 http://www.modelboatbits.com/
NobbySideways
« Reply #4 on: June 03, 2015, 02:11:46 pm »
Thank you
morley bill 1
« Reply #5 on: June 03, 2015, 06:58:39 pm »
Hi if you're using 4mm exposed shafts then any 4mil support will do a V will give more strength than a single leg regards Bill....
NobbySideways
« Reply #6 on: June 03, 2015, 10:31:28 pm »
Ok thanks. Mine is a Fibreglass hull so I assume I just drill a slot for the strut and glue it in place?
Marty
« Reply #7 on: June 03, 2015, 11:52:31 pm »
Have a look on ebay I've seen on a few occasions P brackets for sale.
They might come in useful.
Marty
Never hit the beach with both anchors home
Page created in 0.223 seconds with 18 queries.
