Author Topic: My First Build - Krick Borkum  (Read 8490 times)
jpdenver
  • Just an old fart.
« on: July 06, 2015, 10:26:18 pm »
Greetings from Denver, Colorado.
I just wanted to share my journey.
About 4 years ago I decided to pursue "Steam",  and I chose Stationary and Marine Engines to start.
I re-configured my workshop from wood-to-metal, and acquired a Lathe and a Mill.  I bought Sherline,
in the DRO configuration as I felt that I needed to feel the cutting of swarf, and get a sense of how metal
acted.  I felt that CNC would distance me from that knowledge and experience.
I read every book on Model Engineering I could find (most from the UK), and made a couple of small
engines to get a feel for the process.  Then last year I decided to build a boat, and then have a platform to
put various engines in.  I chose the Krick Borkum  as a good open hull, and a deck I could mount in.
Here are some pics of my shop.
Thanks for reading.
Jim Pope
Denver, Colorado
Son of a Son of a Sailor.
jpdenver
  • Just an old fart.
Re: My First Build - Krick Borkum - The Boat - Engines
« Reply #1 on: July 07, 2015, 02:17:41 am »
After building a number of small engines, I decided to build a boat to run them on.
Decided on the Krick Borkum,  and after reading up on Boilers, I decided that the first one
would be professionally made, and I chose tone from Miniature Steam from Australia.
Then, before I could pick the engine I was going to build, I found a good deal on Ebay from
Microcosim -  A nice little 2 cylinder.
And of course, I insulated and wrapped the pipes.
Here are some pics.
jpdenver
  • Just an old fart.
« Reply #2 on: July 07, 2015, 02:26:49 am »
Now to the Boat.
More Pics.
Enjoy
Thanks for reading,
Jim Pope
Denver
jpdenver
  • Just an old fart.
« Reply #3 on: July 07, 2015, 03:06:27 am »
« Reply #4 on: July 07, 2015, 03:11:29 am »
Welcome Jim........that is a pretty functional looking workshop  :-))......
Not being familiar with the Borkum build, have you checked the all up weight of the components.....[gas tank, gas regulator, boiler, engine, de oiler etc?] plus all other ancillaries.....  and compared to the permissible or required weight for displacement?
Your actual build is progressing well......the well spaced plank colouration also looks good  O0
Does the kit build instructions talk about protecting the ABS hull from overheat?
From your video, the engine appears to run smoothly at less than 1 Bar ...which is good
jpdenver
  • Just an old fart.
« Reply #5 on: July 07, 2015, 04:41:50 am »
Derek,
Thanks for the comments.
The kit was designed to have an engine and boiler about the size I have chosen, and the
instructions include the placement of ballast - so I am assuming that I will be adding some too.
My next set of pics will show the use of some spacer blocks off the lower deck.
The lower deck is about 1 1/2 inches off the ABS hull, so heat is dissipated and the hull protected.
My planned Maiden Voyage is July 18.   Still got a bit to go.
SailorGreg
« Reply #6 on: July 07, 2015, 10:09:20 am »
Lovely build Jim.  And a great workshop you have there.  I am looking forward to the 18th!
Greg
jpdenver
  • Just an old fart.
Re: My First Build - Krick Borkum - Lights
« Reply #7 on: July 07, 2015, 03:40:46 pm »
Added lights to the build.
Embedded LED's in the lanterns.
Found some Receiver Controlled Switches.
I am using a little 5-Channel system.
Channel 5 is for Gear. A 3-Position Switch.
1-off
2-running
3-running and lower deck
Here are pics.
Thanks for reading.
Jim Pope
Denver
jpdenver
  • Just an old fart.
Re: My First Build - Krick Borkum - Servos
« Reply #8 on: July 08, 2015, 04:14:26 am »
Started to put in the servos.
Built some brackets for the Throttle and Reverse Gear.
I also needed to hide a small servo for the whistle.
Hid them in a pile of barrels.
Thanks for reading,
Jim Pope
Denver
jpdenver
  • Just an old fart.
Re: My First Build - Krick Borkum- more of the details
« Reply #9 on: July 09, 2015, 04:36:28 am »
Still working out the small details,
nothing really glued down yet.
jpdenver
  • Just an old fart.
Re: My First Build - Krick Borkum - Final Pics
« Reply #10 on: July 10, 2015, 03:10:39 am »
Next step is to Float the Boat.
Thanks for reading
Jim Pope
Denver
jpdenver
  • Just an old fart.
« Reply #11 on: July 13, 2015, 04:08:55 am »
http://www.youtube.com/watch?v=86mfeoQs4Wo
A walk around the final result.  Just waiting for her
christening.  The Ladye M.
And some pics of her running lights.
Thanks for reading.
I'll post her first run next week.
Jim Pope
Denver,CO
southsteyne2
« Reply #12 on: July 14, 2015, 01:42:53 am »
Very nice Jim can't wait to see her in the water, btw I have the same whistle but find it peters out over 20psi anyone found a fix for this maybe smaller feed pipe? open to suggestions ;D
jpdenver
  • Just an old fart.
Re: My First Build - Whistles
« Reply #13 on: July 14, 2015, 04:39:06 am »
John,
I run my engine at between 15 and 20 PSI,
so the whistle has not had a lot of use yet.
Especially since I have not had her in the water yet.
Have you tried putting a valve in front of  the whistle
to see what % of flow works, then you could put a
flow restriction in place.
On another engine, I have epoxied a piece of tubing inside a std pipe
nipple to restrict the flow.
Just a thought.
Thanks for reading -
Jim
rhavrane
  • Steam passionate collector
« Reply #14 on: July 14, 2015, 08:12:25 am »
Bonjour James (and John),
I also have this whistle on one of my boats and it works well under 2 bars (+/- 30 psi) :
https://www.youtube.com/watch?v=QIbGjiD36xU
To manage higher pressures, I have used another solution, a RC steam valve :
https://www.youtube.com/watch?v=pRBMj0lImus
And for fun, two French Borkum :
Gilles : https://www.youtube.com/watch?v=_UPcOovj-0Q   (2 cc Anton Quartz steam plant)
Patrick : https://www.youtube.com/watch?v=_UPcOovj-0Q (V4 single effect oscillating 4cc personal build + telemetry !)
Raphaël
jpdenver
  • Just an old fart.
Re: My First Build - Krick Borkum- Her Maiden Voyage
« Reply #15 on: July 19, 2015, 03:03:30 am »
Here she is:
https://www.youtube.com/watch?v=jF_OrOduvN4&feature=youtu.be
Thank you for reading,
Jim Pope
Denver, Colorado
southsteyne2
« Reply #16 on: July 19, 2015, 08:05:48 am »
Looks fantastic Jim bet you are pleased as O0
SailorGreg
« Reply #17 on: July 19, 2015, 10:26:11 pm »
Good job Jim - hours of fun ahead for you  :-))
jpdenver
  • Just an old fart.
Re: Her first time in the water
« Reply #18 on: July 23, 2015, 05:25:30 pm »
Here are some clips from her first time afloat.
Where she was close enough to be heard.
For those of you that want to hear the engine.
https://www.youtube.com/watch?v=O_IAnurd8H8&feature=youtu.be
Thanks again for the encouragements.
Regards to all,
Jim Pope
Denver, CO
USA
rhavrane
« Reply #19 on: July 23, 2015, 06:53:08 pm »
Bonjour James,
My comment on this beautiful launch on the video...  ok2
Raphaël
Page created in 0.155 seconds with 18 queries.
