Purely from a mechanical point, one would consider a stainless steel washer rotating against a stationary brass bush or tube end, with water as the lubricity be superior to a nylon washer in the same application
It is acknowledged that pure Nylon does not absorb or swell in water .....however there are so many generic names for thermoplastics...& they all look the same in a billet of bar stock, but alas some absorb and swell with water or and an increase in heat
which can occur in out of water bench testing
We also consider that with a prop shaft tube, there will be a minute migration of lubricant from the grease packing
I still have a 1/2 a jar of
Dow Corning rubber grease
......which was the forerunner of todays commercial waterproof bearing grease .....
With respect to longitudinal clearance, yes by all means and say 0.003 to 0.005" in this type of application is fine....remembering it is essentially negated by directional rotation thrust
Yes in both directions, the actual prop shaft is in tension created by that same directional rotational torque/thrust .......
However in real marine applications, an inboard propeller shaft thrust bearing assembly can be the size of a 200 litre drum or a very large tea chest........
...Derek
. Derek
