Author Topic: Silicone tube help  (Read 5910 times)
david48
Silicone tube help
« on: August 18, 2015, 11:03:42 pm »
Pleased can any one help, I require 65mm of silicone tube 12mm ID, OD can be anything but ,2mm wall thickness would be good . I have found web sites but with a minimum order of  1 mtr .
 Thank you
David
inertia
Re: Silicone tube help
« Reply #1 on: August 19, 2015, 08:37:05 am »
Sorry - posted a reply then re-read your specs! The stuff I have is only 10.5 OD. I'll have a root around to see if I've anything nearer. Did you see the link I gave to Ken Churchill https://www.polymax.co.uk/silicone/silicone-tubing ? They have exactly what you need at £4/metre.
Dave M
« Reply #2 on: August 19, 2015, 09:41:44 am »
Not silicone, but I do have some of this in 12/16mm
https://www.eheim.com/en_GB/products/accessories/installation/hoses
« Reply #3 on: August 19, 2015, 10:33:22 am »
Yes,  mine is on order and should be here in a day or two.  I will report on its quality when I see it.  Mine was 2mm  inside diameter but I chose 2mm walls so I'm hoping it's not two thick.   %)
cheers
radiojoe
« Reply #4 on: August 19, 2015, 10:57:24 am »
you can get silicon tube of various sizes from www.modelshopleeds.co.uk in 300mm and 150mm.long not cheap though {:-{:-))
david48
« Reply #5 on: August 19, 2015, 11:23:31 pm »
Thanks for the replys , I saw the Polymax link Dave, when I highlited it it came up as min order 5 I assume this to be meters or have I misunderstud.ive just checked and it is 5meters works out at well over £20 and just for 65mm it's a bit to dear even for me
Thank you E2V but sending it from Finland would be two much for what I was after .
I will have a look on  Leedsmodelshop there's is 12.7 and would be to slack a fit .
I'll tell you what it's for ,it was to sleeve over a Huco coupling just to see if the noise was reduced , it was just a fancy idea I had . I know there are silicon drive couplers ,but I don't like that idea . Polymax do samples so it might try them but I will ring them .
Thanks again David .
« Reply #6 on: August 19, 2015, 11:29:04 pm »
I'm in the UK at the moment :)
david48
« Reply #7 on: August 19, 2015, 11:41:01 pm »
Ahh that's different , as I have said I only want 65mm . How would that work ,
David
Chris57
  • Fishers Green mbc
« Reply #8 on: August 19, 2015, 11:52:18 pm »
If your coupling is straight, you could perhaps try a little heat shrink, which would give a tight fit?
Chris
david48
« Reply #9 on: August 20, 2015, 12:01:48 am »
Yes it is I have checked it with the DTI gauge and the is no run off ,good spot the heat shrink ,I give it a try, thanks for that
David
inertia
« Reply #11 on: August 20, 2015, 10:44:58 am »
Martin
I think the 65mm refers to the length - not the ID.  O0
David
I've converted all the Huco-type couplings in my models to flexible drive, with the tubing pushed over the splined parts of the adaptors, and they all work just fine - even at high speeds. Cut the tube to the same length as the plastic UJ piece that it's replacing. IMHO this is a better option than sleeving the whole thing as it removes the cause of the noise and vibration rather than just muffling it. I'd be happy to send you a short length to try it if you remind me of your postal address via PM.
Dave M
radiojoe
« Reply #12 on: August 20, 2015, 11:06:37 am »
modelshopleeds do have smaller sizes than 12.7 ID  put silicon in their search box,  they have 11mm ID which might suit.  :-))
« Reply #13 on: August 20, 2015, 10:05:36 pm »
I go along with Dave.  Mine arrived today and it connects   shaft to shaft  with a self tightening fit. No need for couplers inside.   Mind you,  I had to buy a metre so have loads left over for future boats.
Dave Cook
  • Cookie
  • Keep on Rockin
« Reply #14 on: November 10, 2015, 03:25:59 pm »
Hi Dave M , Interesting , do you think your method of flexi drive would deal with larger boat ( 1:24 Perkasa ) running on brushless.
Best Regards Dave ok2
Page created in 0.222 seconds with 18 queries.
