Author Topic: Minicraft/Revell Titanic  (Read 3727 times)
U-33
  • K-157 Vepr. Akula-11
« on: August 20, 2015, 01:35:18 pm »
Anyone converted the 1/350th Titanic to r/c? If so, how did you arrange access to the internals for charging, maintenance, etc? And if possible, has anyone got any photos showing the internal layout, please?
Cheers guys,
irons01
  • 1/72 HMS Hambledon built and sailing....
    • Facebook build page
Re: Minicraft/Revell Titanic
« Reply #1 on: August 20, 2015, 02:02:18 pm »
Some info on youtube here: https://www.youtube.com/watch?v=p8vhA-fjAKQ  (not mine, just something I recall seeing before)
U-33
« Reply #2 on: August 20, 2015, 02:15:00 pm »
Thanks for that, Irons...much appreciated and very useful.
« Reply #3 on: August 20, 2015, 09:43:25 pm »
Watching with interest Rich.  I have this kit (not built) and there's plenty of space inside.  The secret way- in is to have removable  'A'  deck to get inside.
Subculture
    • Dive-in to Model submarines
« Reply #4 on: August 21, 2015, 05:09:56 pm »
I'm not in engaging in black humour when i suggest that may be you might want to think about using construction methods more appropriate for a submarine.
Thinking about the equipment you need, and bearing in mind that very small kit is available these days, I think I would get a tiny servo, receiver and esc, and put them inside a small watertight enclosure, and then use light polystyrene foam to fill areas inside the hull. This will genuinely make your Titanic unsinkable. Any wet that gets past the deck won't harm the electronics
Batteries and motors can live outside the box.
U-33
« Reply #5 on: August 22, 2015, 07:25:36 am »
That's not a bad idea, Andy...these plastic conversions tend to be calm water boats, but there's always the chance of water getting in somewhere.
U-33
« Reply #6 on: August 22, 2015, 09:25:14 am »
Here we go then...a couple of dry runs. I'm going to try using the kit rudder if I can, but failing that I'll just use tank style steering on the two 280 motors.
Mad Scientist
« Reply #7 on: August 22, 2015, 08:26:45 pm »
Small rudder - no wonder RMS Olympic had a bad habit of running into things. - Tom
Page created in 0.163 seconds with 18 queries.
