Well that didn't go as well as hoped!
First off, trying to line the hull with smooth cling film was impossible. In the end I decided that a few dozen wrinkles & creases weren't that important.
Second off, I opted for the Screwfix rapid set manual foam canister. The trigger spout mechanism was useless. - there was no mechanism, the trigger was just a solid lump of plastic moulded with the rest of the spout i.e. no moving parts. Took it back and swapped for the standard manual foam canister which has a totally different spout.
I half filled the hull with foam and left it overnight. In the morning it looked like the picture below (STOP laughing)
The beam had increased by at least 7mm so it would be no good if scale (it isn't so I don't mind).
16hrs after foaming I prized the foam out only to find that it had not set at the bottom of the hull. I put it back in quickly and left another 24hrs, I've just prized it out again only to find that, A) it still hadn't entirely gone off & B) the first prizing out had damaged the cling film and I now had foam stuck to the styrene.
"Oh sugar" was approximately what I said.
Of course, generally stuff that dissolves foam also dissolves styrene. Luckily the stuck bit of foam had not entirely set so I managed to remove it using Isopropyl alcohol ('though meths would probably have worked) and I am left with just a slight yellow stain. (In the hull, not in the trousers
If the foam ever sets properly I'll see if I can get any useable slices out of it. Otherwise it's back to the cereal packets etc and all I've wasted is some cling film and a can of foam.
NNF
