Author Topic: Anyone got Nipples like these  (Read 5623 times)
« on: September 04, 2015, 07:52:32 pm »
This is the Stuffing tubes just  uncovered  on my boat. I thought  they might have just been tubes but the  ball bearing is sprung loaded . Question anyone know of a grease gun that fits wee ones like this or is it just a Syringe and pressure that depresses the Bearing
Jay
nivapilot
  • re-invented rc boater
Re: Anyone got Nipples like these
« Reply #1 on: September 04, 2015, 08:40:52 pm »
they are oiling nipples, just like they use on lathes.
you need an oil gun with a spring loaded spout, as you press it onto the nipple, the ball bearing is depressed, pumping oil in and as you remove, the ball reseals the nipple.
like this one.....http://www.ebay.co.uk/itm/Pump-Oil-Gun-for-Myford-Lathe-/121732537121?hash=item1c57d31b21
« Reply #2 on: September 04, 2015, 10:03:26 pm »
Hi Jay,
I've used those Graupner oiler nipples.... mine leaked (oil)  ....a Lot!
« Reply #3 on: September 04, 2015, 10:16:08 pm »
Notice how many views this topic has had already - mostly disappointed I imagine!  ok2
« Reply #4 on: September 04, 2015, 10:18:27 pm »
Hi Jay,
I've used those Graupner oilier nipples.... mine leaked....a Lot!
then you need these:-
Well some one had to  ;D O0 {-) %%
« Reply #5 on: September 04, 2015, 10:22:45 pm »
Hi Jay,
 Water or oil Martin  mines are  dry and I've never used them yet oilwise
« Reply #6 on: September 04, 2015, 10:31:10 pm »
Thanks Nivapilot   I was depressed to when I saw the price :}  methinks    a heath robinson solution  required
Jay
barriew
« Reply #7 on: September 05, 2015, 06:41:49 am »
This is slightly cheaper and has a point which you may be able to use to depress the ball.
Barrie
http://www.ebay.co.uk/itm/Mini-grease-gun-for-precision-application-pistol-tool-kit-with-grease-tube-/140898996204?ssPageName=ADME:L:OC:GB:3160
nivapilot
« Reply #8 on: September 05, 2015, 08:08:02 am »
Press down on the ball with a sharpish pointy thing and drip oil in from a proper oil can? :-))
« Reply #9 on: September 05, 2015, 09:41:15 am »
Thans guys have it in mind to  eventually try a small syringe with a bit of poly tube  and  some kind of pin inserted in the syringe .Though as its never been done in the few years I've had her ''If it aint Broke''
Jay
« Reply #10 on: September 05, 2015, 10:40:23 am »
You could try oil in a ball point pen with the insert removed.   %)
ken
Danny
  • Gorleston Model Boat Club
    • Gorleston MBC
« Reply #11 on: September 05, 2015, 11:59:07 am »
Or just unscrew them (probably 1/4" thread) and buy three 'normal' grease nipples to replace them.
The number of 'reads' may be to do with the fact that in the index, this topic shows as -
"Anyone got nipples ...".
Disappointment indeed!
« Reply #12 on: September 05, 2015, 01:00:13 pm »
Good thinking Ken  along the same as a syringe  with say a cocktail stick inserted  to keep the oil in then released as the ball is depressed
 Sorry to disappoint Danny bit like all the people attending  court when a particular judge renowned for his wit and sarcasm was on
 as they heard there was always a Titter ran through the crowd
Tis all in the mind {-)
mrsgoggins
« Reply #13 on: September 05, 2015, 07:49:22 pm »
I Googled "nipples" and ended up here.
bj
« Reply #14 on: September 05, 2015, 07:56:40 pm »
We went "Metric" last century - M5, M6 maybe. Having said that they are not conventional GREASE nipples, they appear to be oil nipples. Conventional grease nipples are cone shaped with a 'ball' head. An alternative is a 'TAT' type nipple.
Lever arm grease guns hit around 5000psi see http://www.ebay.co.uk/itm/like/131326198702?adgroupid=&hlpht=true&hlpv=2&rlsatarget=&adtype=pla&ff3=1&lpid=122&poi=&ul_noapp=true&limghlpsr=true&device=c&chn=ps&campaignid=&crdt=0&ff12=67&ff11=ICEP3.0.0-L&ff14=122&viphx=1&ops=true&ff13=80 as low cost example.
PICKETBOAT
  • PICKETBOAT
  • "History in the making"
    • Chylds Hall Model Shipyard
« Reply #15 on: September 22, 2015, 07:28:20 pm »
Hi all
Just noticed this post (having arrived at it via logging in rather than from any dodgy Google searches honest). What about replacing the spring with a less powerful one or shortening the existing one. Then just the pressure from the in coming oil/grease in a syringe might work.
I hate grease in stern tubes. I creates immense amounts of drag and then eventually sets hard when you shelve the model for a few months.
Page created in 0.488 seconds with 17 queries.
