Author Topic: Servo to operate a Tamar mast  (Read 2474 times)
gerard
« on: September 10, 2015, 01:33:05 pm »
Hi all, looking for advise as to what type of servo would be best used to operate the mast on a Slipway Tamar. will proberley be linked direct. what size , type of gears, could you suggest, any help will be appreciated. Gerard
david48
Re: Servo to operate a Tamar mast
« Reply #1 on: September 10, 2015, 08:10:34 pm »
Have you looked at a linnear type servo,maby with a bell crank arrangement , just my threepenny worth .
David
« Reply #2 on: September 10, 2015, 08:54:22 pm »
This - http://www.ebay.co.uk/itm/NEW-EMS-Linear-Servo-Conversion-Kit-S148-EMO0102-NIB-/291341853059 - might give the right travel using a standard servo, but might still be a bit sudden unless the servo was fed via something like a servo morph to slow its reaction down.  A standard servo with a servo speed modifier might well do the job.
If more torque is needed, and space available, a 2 turn winch as sold by component-shop (up to about 7" of travel on the line).
Essentially, its the same job as the flyboys use for retracting gear.
gerard
« Reply #3 on: September 11, 2015, 08:55:47 pm »
Thanks for that, will look into these linear servo's and see if it will work for me ,regards Gerard.
Page created in 1.758 seconds with 17 queries.
