Author Topic: Newbie question about Spektrum DX6i  (Read 3006 times)
Norman Castle
« on: September 16, 2015, 06:27:47 pm »
Aeromodeller here working up to taking the first steps into things nautical, and I'm immediately scratching my head about something pretty basic.
I gather that boat ESCs have (or can have) forward and reverse, but how might that work in conjunction with the Spektrum DR6i TX which I use for my model aircraft?  Surely I want my throttle stick to be "off" in the middle of its travel, rather than the bottom of it?  I can't imagine how this forward/reverse lark is actually done!
Also, is there anything special about the RX used on a boat, or will one of my aircraft ones do the job?
A positive attitude may not solve all your problems, but with any luck it will annoy enough people to make the effort worthwhile.
Re: Newbie question about Spektrum DX6i
« Reply #1 on: September 16, 2015, 06:44:05 pm »
Just rebind the rx with the stick central when using
in a boat.
The set up is then on the esc for ahead and astern.
You can set up throttle limits with the Tx programme
if needed.
barriew
« Reply #2 on: September 16, 2015, 07:09:23 pm »
Or do as I do and use the right hand (self centring) stick for the throttle  :-))
Barrie
Norman Castle
« Reply #3 on: September 17, 2015, 06:51:15 am »
Thank you gentlemen.  That's one mystery solved  :-)
« Reply #4 on: September 17, 2015, 08:34:39 am »
It's quite an easy job to convert the gimbal to a sprung centre.
There are kits available online
Captain Flack
« Reply #5 on: September 17, 2015, 12:49:11 pm »
Surely aircraft ESCs don't have reverse :(( and you need an ESC that doesn't have braking, or if it does that you can turn it off.
« Reply #6 on: September 17, 2015, 01:29:36 pm »
The question was about aircraft receivers not esc's I think.
Klunk
« Reply #7 on: September 17, 2015, 01:59:42 pm »
Surely aircraft ESCs don't have reverse :(( and you need an ESC that doesn't have braking, or if it does that you can turn it off.0
I always use braking on my esc in a boat.
full time penguin
Page created in 0.594 seconds with 17 queries.
