Author Topic: Filling grain  (Read 3639 times)
Glyn Roberts
  • Creativity is contagious, pass it on.
Filling grain
« on: September 29, 2015, 04:56:09 pm »
I have started a new build  (Scratch veron huntsman)  and was thinking about the finishing and remembered this.   "years ago I built a plywood door to replace a damaged door and when I came to paint it I noticed how deep and open the grain was so I mixed some exterior polyfilla to a creamy consistancy and brushed on to the ply.  I then scraped the surplus off with a card and allowed to dry. Afer an easy rub down with a block it was primed and painted, the finish was like a mirror."  I intend to try this on the huntsman.
Has any one tried that, and if so how did it work out for you.
Regards Glyn
Umi_Ryuzuki
    • Models and Miniatures
Re: Filling grain
« Reply #1 on: September 29, 2015, 05:40:09 pm »
I usually use a sanding sealer.
Barring actually finding such a finisher, I substitue a satin finish laquer.
It has a filler to disrupt the gloss finish, and sanding between coats will act
like a sanding sealer to fill grain and smooth the finish.
Glyn Roberts
Re: Filling grain
« Reply #2 on: September 29, 2015, 08:12:28 pm »
Hi Umi Ryuzuki,
Thanks for that interesting tip.
Re: Filling grain
« Reply #3 on: September 29, 2015, 08:54:35 pm »
I allways use Halfords car laquer the Primer and the primer filler ever had a problem with the grain showing through and looks like a grp hull when done
chas
Re: Filling grain
« Reply #4 on: September 30, 2015, 08:42:20 am »
Yes, I've done it, on ply and balsa. I mixed some pva in to give adhesion. The earliest model is 10 years old and still fine. Cheaper and less smelly than sanding sealer, works very well.
Charles.
inertia
Re: Filling grain
« Reply #5 on: September 30, 2015, 08:47:59 am »
On my most recent Liteply model I used Fine Surface Polyfilla, which is a vinyl-based, ready-mixed spackle. It was applied with an old plastic bank card, allowed to dry (which didn't take long) then sanded back with 320 silicon-carbide finishing paper. Worked a treat.
DM
inertia
Re: Filling grain
« Reply #6 on: September 30, 2015, 10:50:51 am »
Here's a couple of photos - model was then covered with lightweight glass cloth and resin.
Glyn Roberts
Re: Filling grain
« Reply #7 on: September 30, 2015, 07:53:42 pm »
Thanks to all who shared their methods, it was good to find that others had the same ideas that worked. Any shortcuts are good if one is scratch building a large boat and the main parts have to be traced, drawn, and cut, and the ply is 6mm cut with cope or fret saw by hand, good stuff but hard work for oldies like me.
Regards Glyn
