Author Topic: Lettering for ships name etc.  (Read 4170 times)
bilgerat
  • It wasnt me officer, some big boys broke it!!
« on: October 09, 2015, 05:45:51 pm »
Question - have had a search through but unable to find an answer to this one, so here goes:
Lettering for ships names, has anyone ever tried using one of those brother label printers. You can get clear label film and black or white lettering. Has it been done, does it work, does it need a coat of satin varnish ?????
I await with anticipation any useful input........... {:-{
cheers
Trev
Officer of the watch to helmsman - who is the idiot on the end of this voicepipe. Reply from helsman - "which end sir?"
sparkey
Re: Lettering for ships name etc.
« Reply #1 on: October 09, 2015, 06:12:10 pm »
 :-)) I have always used Barry's model lettering,cheap and easy to use just give them a ring and tell what you want and in a couple of days you have the names for your boats,all my boats names are made by them good quality and hard wearing,and no I don't anything to do with them just a happy customer......Ray. :-)) :-)) :-)) :-)) :-))
« Reply #2 on: October 09, 2015, 06:38:45 pm »
Unless you have a fleet to label then it is an expensive way of doing it.
Different scales and different fonts Costa lotta.
Barry's Modelling Lettering is the way most of us go.
Seaspray
« Reply #3 on: October 09, 2015, 06:56:37 pm »
I use Barry's and BEC lettery and deck hull markings  and also I make my own using Crafty Computer Paper .
Also if I can't get the colour of lettering I want I spray to the colour I want
Brian60
« Reply #4 on: October 09, 2015, 07:03:33 pm »
I now print my own on decal paper. But in the past you can get rub on lettering, it used to be called Letraset, but there are plenty of generic variants, WHSmith have their own. But with the advent of computers and home printing they are very few sizes and colours nowadays, usually black or red.
« Reply #5 on: October 10, 2015, 01:00:34 am »
depending on the size/colour of the lettering I can do them for you in automotive grade vinyl
Brian60
« Reply #6 on: October 10, 2015, 09:47:51 am »
I can vouch for E2V, he has done some superb lettering for me (check out the POSH on my posh venture) when barrys model lettering turned me down flat saying it couldn't be done.
« Reply #7 on: October 10, 2015, 09:59:23 am »
Those were easy.
There is a size limit tho.... I tried to do some for Dave M (inertia) but they didn't come out so well, but then they involved some quite intricate lettering at about 6mm High
bilgerat
« Reply #8 on: October 12, 2015, 11:41:05 pm »
Thanks for the replies chaps, all most useful.
tonyH
« Reply #9 on: October 13, 2015, 03:57:17 pm »
If you want the 3D warship nameplates, use the Plastruct styrene letters, mount them on a piece of plasticard with a frame if required, then push the master board into some plasticene with a bit of silicone spray as a release agent and mould as many as you want with a bit of resin mixed with talc. The letters go down to about 3mm high,
Works for me :-))
Tony
Stan
« Reply #10 on: October 13, 2015, 04:56:01 pm »
Hi Guys not sure if this what are looking for. Ships name done using Slater's letters. Paint them first then fit them on to Tamiya masking tape then super glue to model. Hope this helps.
Stan.
