Author Topic: Azimuth alternatives?  (Read 8679 times)
Blaven03
« on: October 10, 2015, 04:07:16 pm »
Hello all,
Hope this is in the correct section.
I was wondering if there are any alternative asd builders to graupner.
Any help appreciated.
Big Ada
Re: Azimuth alternatives?
« Reply #1 on: October 10, 2015, 05:47:11 pm »
Krishna makes his own.
« Reply #2 on: October 10, 2015, 06:26:55 pm »
Do you mean the Azimut / Schotle drive  unit?
Marx used to do one...  http://www.ebay.co.uk/itm/Rudder-Prop-Drive-with-Kort-Nozzle-/131623986933?hash=item1ea566a6f5
Blaven03
« Reply #3 on: October 10, 2015, 06:36:43 pm »
Yes that's what I mean. My mistake. Is Marx a supplier.
Umi_Ryuzuki
    • Models and Miniatures
« Reply #4 on: October 10, 2015, 06:39:38 pm »
The Marx are long out of production.
Although people still seem to be able to find units second hand.
Bauer Modelle appears to offer the old Graupner Schottel I and II, and
several custom version should your pocket book be well padded.  :-))
http://www.bauer-modelle.de/modules/wsShop/index.php?location_id=151&cat_id=83507&wslanguage=en
Blaven03
« Reply #5 on: October 10, 2015, 06:50:35 pm »
Thanks for that. A large pocket book indeed but the option is there.
Umi_Ryuzuki
« Reply #6 on: October 10, 2015, 07:10:24 pm »
The 40mm and 50mm Schottel Antrieb on the bottom of the second page are
Bauer's production version. From what we can gather they use the top end of the
Graupner Schottel I, but have a different bottom end drive shape.
Blaven03
« Reply #7 on: October 10, 2015, 08:53:00 pm »
They look ok, I'm looking for schottels for a 1/50 asd tug,  most schottel predrude too far or the props are two small for any power, try to find the happy medium.
Umi_Ryuzuki
« Reply #8 on: October 10, 2015, 10:58:29 pm »
I used the Graupner Schottel I on my 1:48 SDM tug.
It is able to achieve a solid 2.5 lbs (1.13kg) bollard pull on the fish scale.
carlmt
    • Linkspan Models
« Reply #9 on: October 10, 2015, 11:37:36 pm »
Hmmmmm - I like the look of these POD drives.......
http://www.bauer-modelle.de/shop/408972/83511/151/schottelantriebe/praezisions-pod-antrieb-40mm#
Would need 2 for a Stockholm Archipelago ferry we are looking to produce - but at nearly 500 euro EACH, we may need to source something else!!!!
« Reply #10 on: October 10, 2015, 11:51:19 pm »
 ;)...yes Carl..... but they are a beautiful piece of engineering  :-))...and the belt drive for both propulsion and direction is another brilliant concept  O0 .....
An alternate supplier appears to market them for 318 Euro  :o.......and provides dimensions too........Derek
Umi_Ryuzuki
« Reply #11 on: October 11, 2015, 12:03:45 am »
In answer to the question, are the small graupner drives enough for towing.
Yes.
SDM on a barge(sideways).
SDM tug pushing 900 lb pumpkin.
The Springer tug, single 40 mm propeller pushing 1400 lb pumpkin.
Okay, 1447lbs. (656.34kg)
« Reply #12 on: October 11, 2015, 12:11:30 am »
We see the pumpkin floats even at 1447 lbs  {-).......but that's a lot of potential pumpkin soup there Umi.......  :o....... Derek
GAZOU
« Reply #13 on: October 11, 2015, 09:27:42 am »
  ok2
To maneuver your pods azimuth that is what you need: a module 360 °
It is plug play.
It is very small.
It costs only 129 euros net (except freight)
To compare with the market.
Two versions in the kit
No radio modification with rotary contact VR A for the throttle
Two small welds for the (provided) stick, the rotary contact is then at the end of (provided) stick
The throttel is thus transferred by VR Has towards the stick and the rotary contact VR A neutralized
Brian60
« Reply #14 on: October 11, 2015, 09:29:12 am »
Think yourself lucky, a future build of mine has 4 of these!! I'm building my own, may not be as pretty as those but they will still work
Blaven03
« Reply #15 on: October 11, 2015, 12:24:10 pm »
Gazou,
Is there an idiots guide to how this system works cause I'm fairly new to this.
Best luck wiv your build Brian.
Best of luck pushing thos pumpkins, they are huge
GAZOU
« Reply #16 on: October 11, 2015, 01:29:54 pm »
 ok2
Hello
Yes there is a note in English but there is détrompeurs where it is necessary.
There is no possibility of destroying the module and no possibility of misadjustment. There are securities everywhere. Impossible to connect back to front.
You connect the module by respecting the photo n°1
You put your pods in the neutral in the hand.
You initialize and it is in office. That's it.
Umi_Ryuzuki
« Reply #17 on: October 18, 2015, 01:04:58 am »
Gazou, you never answer where or when the Seapod 360° will be available for purchase.
As for the Graupner drives, my largest two tows to date.
Today at the pumpkin regatta.
1167 lbs(529.34kg), and 1,234 lbs(559.73kg)  O0
Todays winner at 1794.5 did not go into the water.
Many other pumpkins went to the races.  :-))
Page created in 0.465 seconds with 17 queries.
