Author Topic: RAF Tender??  (Read 14466 times)
goBulawayo
Re: RAF Tender??
« Reply #25 on: November 03, 2015, 07:09:21 pm »
More pics
Props before cleaning
Props after cleaning
Re: RAF Tender??
« Reply #26 on: November 03, 2015, 08:40:15 pm »
Wayne.................those props certainly look to be a good profile & design after cleaning :-)) and for the style and vintage of the vessel, brass/bronze aged finish always looks better than red paint
I certainly do not know the answer, however it may be best to research the direction of the props......ie., either inboard turning or outboard turning.... again I understand you are not sure of the exact Class of vessel, however I suspect most types of this general design would have similar handed drives.......Derek
goBulawayo
Re: RAF Tender??
« Reply #27 on: November 03, 2015, 09:19:49 pm »
Hi Derek, I had thought inward turning, but I didn't think they might be outward turning?
Wayne
goBulawayo
Re: RAF Tender??
« Reply #28 on: August 08, 2017, 07:07:27 pm »
been working on this boat again - plenty of sanding and filling and primer and sanding, it wont be perfect but as a rebuild will be OK. I have also been drawing up a new superstructure - Will build a card model of it to see how it looks once I have the hull sorted.
Wayne
https://www.flickr.com/photos/22510111@N07/35192397394/in/dateposted-public
https://www.flickr.com/photos/22510111@N07/36280081192/in/dateposted-public
https://www.flickr.com/photos/22510111@N07/35640538003/in/dateposted-public
https://www.flickr.com/photos/22510111@N07/35640543073/in/dateposted-public
RAAArtyGunner
Re: RAF Tender??
« Reply #29 on: August 09, 2017, 01:09:41 am »
 :o :o :o
A bit useless after the bucket problems to continue to not directly post photos to the thread.
This thread is useless as it is >>:-( >>:-(
Re: RAF Tender??
« Reply #30 on: August 09, 2017, 02:59:43 am »
For now, we invite members to repost their photo in a new post and the mods to re-insert new photo back to original posts.  :-)
goBulawayo
Re: RAF Tender??
« Reply #31 on: August 09, 2017, 06:19:41 am »
:o :o :o
Well I tried to add the photos using the photo button but they would not show, so you will have to make do with the links - if that does not suit you, nothing I can do - Wayne
Re: RAF Tender??
« Reply #32 on: August 09, 2017, 01:19:58 pm »
Easy enough to do.....  ok2
goBulawayo
Re: RAF Tender??
« Reply #33 on: August 09, 2017, 06:31:10 pm »
Right worked it out, do not need the image button - Some of the older pics - you can see the old superstructure in the one photo - That has been thrown away as it was awful
2015-10-25 21.00.12 by Wayne, on Flickr
2015-10-25 21.00.06 by Wayne, on Flickr
2015-10-25 20.59.53 by Wayne, on Flickr
2015-10-28 18.40.49 by Wayne, on Flickr
2015-10-28 18.41.48 by Wayne, on Flickr
2015-11-02 18.32.45 by Wayne, on Flickr
IMAG1551 by Wayne, on Flickr
IMAG1550 by Wayne, on Flickr
Re: RAF Tender??
« Reply #34 on: August 09, 2017, 10:57:16 pm »
RAAArtyGunner
Re: RAF Tender??
« Reply #35 on: August 10, 2017, 07:35:08 am »
Thank you. :-)) :-)) Also to Martin,
You have a task ahead  O0 O0
goBulawayo
Re: RAF Tender??
« Reply #36 on: August 22, 2017, 08:54:44 pm »
Right the rudders have arrived, can anyone direct me to somewhere that sells control horns suitable for 3mm rod that have a grub screw to attach them, I need a right angle control horn and a single arm though I can cut off one of the arms on the double arm one I have - Many thanks Wayne
